Unable to add media
erilod
Post Tue Jan 20, 2015 9:46 am
Unable to add media
Just installed Serviio 1.5 on Debian Jessie server (no desktop).
FFmpeg installed
Java 8 installed
Also installed php web ui v1.4beta.
The web UI displays as expected in my browser.
I can add a folder to the library. But when I press "save", the added folder disappears and no content (from the folder) is added.
How can I trouble shoot this?
Thanks!
/Erik
Post Tue Jan 20, 2015 10:40 am
Re: Unable to add media
is there something in the server serviio.log? It looks like the webui version is either old or has not fully implemented all the 1.5 API changes
erilod
Post Tue Jan 20, 2015 12:25 pm
Thanks for a quick reply. Great support as always!
Here's the last 400 lines of serviio.log.
Is there another way apart from PHP Web UI to add media and configure Serviio?
Please keep in mind I run a Debian server (headless) so I have no desktop.
serviio-log.txt
(35.97 KiB) Downloaded 431 times
Post Tue Jan 20, 2015 1:05 pm
Yes. Looks like incompatible version. You could try the latest webui version from viewtopic.php?f=17&t=12593
Otherwise, if you have Android device, give ServiiDroid a try
erilod
Post Tue Jan 20, 2015 5:56 pm
Thanks!
Updating the PHP Web UI made it a bit more "robust" but the upload still didn't work. The log reviled this error message:
2015-01-20 18:36:08,253 WARN  [ServiioStatusService] UnknownFieldException occured. Returning error code 500 to the REST layer. Message: No such field org.serviio.ui.representation.SharedFolder.scanForUpdates
---- Debugging information ----
field               : scanForUpdates
class               : org.serviio.ui.representation.SharedFolder
required-type       : org.serviio.ui.representation.SharedFolder
converter-type      : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
path                : /repository/sharedFolders/sharedFolder/scanForUpdates
class[1]            : java.util.ArrayList
converter-type[1]   : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2]            : org.serviio.ui.representation.RepositoryRepresentation
version             : 1.4.7
But I installed the android app and it worked wonderfully. Congratulations on a great app. I bought the donation key immediately. :D
Post Wed Jan 21, 2015 10:58 am
yes - you need the version that is compatible for 1.5. It will appear on the wiki, once it's available:
http://wiki.serviio.org/doku.php?id=phpwebui
