Kind of on to something!!!
DaFerociousBeast
Post Sat Jan 24, 2015 3:44 pm
ATTN: ZIP
PLEASE RESPOND.
viewtopic.php?t=16461
Was working on this and came across another post:
viewtopic.php?f=6&t=4134
v0.5.2 Does work with my device....and plays media fine too!!!
Any changes on UPnP/DLNA communications after that version?
Even tried using the same Java (Java 6 Update 23 (64-bit)), with other versions, but no luck.
Anyway to run multiple instances of Serviio, v0.5.2 & v1.5 at the same time?
I need access control for other devices, maybe access control breaks something, because v1.0 is when you implemented it.
What version of Serviio is this person running: viewtopic.php?f=7&t=4077&p=97546#p97546
Seems to be able to access it.
Thanks in advance.
Post Sun Jan 25, 2015 2:41 pm
Re: Kind of on to something!!!
Can you post detailed log of 0.5.2 running on your server? need to compare with what you posted here: viewtopic.php?f=5&t=16461#p90040
DaFerociousBeast
Post Sun Jan 25, 2015 5:06 pm
Thanks for responding!
Will do. Give me a day or two.
DaFerociousBeast
Post Sun Jan 25, 2015 6:02 pm
Had a few minutes....
serviio.7z
Had to use 7zip. File is over 500kb
(36.24 KiB) Downloaded 367 times
Post Mon Jan 26, 2015 10:52 am
Thanks. I've noticed something, need to investigate.
DaFerociousBeast
Post Mon Jan 26, 2015 5:13 pm
Just let me know.
Patch or anything?
Appreciate the help!
DaFerociousBeast
Post Fri Jan 30, 2015 4:16 pm
Hows the investigation going?
Post Fri Jan 30, 2015 10:20 pm
The initial lead I was thinking of was incorrect. I've tried something else, but not giving it much chance ;-)
I'll add you to the beta group, so give it a try once the beta for 1.5.1 is out.
DaFerociousBeast
Post Sat Jan 31, 2015 2:46 am
OK. Any time frame on the beta, and how do I go about downloading, when its available?
Post Sat Jan 31, 2015 11:34 am
DaFerociousBeast
Post Sat Feb 07, 2015 4:11 pm
Zip, any timeframe on the next beta release?
Post Sun Feb 08, 2015 11:55 pm
Soon
DaFerociousBeast
Post Tue Feb 10, 2015 12:37 am
You weren't joking!
I'll let you know how it works out.
DaFerociousBeast
Post Tue Feb 10, 2015 1:52 am
Good! Can access server now.
A little bug. The device has categories for video, music, and pictures.
They all only show music.
I can access videos and pictures, only if I go directly to the server itself.
I'm going to look for a link of the GUI of the device. I'll post it later.
Anyway, thank you, you solved the major problem!!
DaFerociousBeast
Post Tue Feb 10, 2015 2:05 am
This is the server screen
http://www.missingremote.com/legacy/img ... ew/hp1.jpg
This is the video screens
http://winsupersite.com/site-files/wins ... nviron.png
http://www.missingremote.com/legacy/img ... ew/hp2.jpg
This is the main GUI, you can see the icons for the media type
http://www.wegotserved.com/wp-content/u ... 7/wmc1.jpg
All I get is the presentation categories for music in all three device categories.
Post Tue Feb 10, 2015 10:46 pm
post your detailed log browsing to videos in the beta forum, thanks
Users browsing this forum: No registered users and 60 guests
