remote access not working... opened all ports!
spikerules
Post Sun Feb 08, 2015 6:46 pm
Hi all,
I've opened all the ports required on both my router and software firewall and am still unable to see the server on my android device over 4G. Can someone please help? I have the pro account which is required to gain access to the remote tab...
I'm at a loss as to what to do:(
Clumsy007
Post Mon Feb 09, 2015 10:43 am
Re: remote access not working... opened all ports!
have u made sure you are trying to access over the external ip of your router?
Post Mon Feb 09, 2015 1:47 pm
Also, how are you attempting to access the server on your phone: using a web browser and your home IP address, or do you have a domain name for your home? Does your home router have a static IP, or are you using a dynamic DNS service?
DaFerociousBeast
Post Tue Feb 10, 2015 1:21 pm
I use ServiioGo.
Opened ports? Serviio will automatically open Windows firewall ports.
By opening router ports, you do mean port forwarding to the server ip?
If using a browser, you are putting "IP:port number". IP is external or DDNS.
There's a button on the remote tab in the Serviio console to check for connectivity also.
Ports are 23424 TCP & 23423 TCP/UDP right?
Users browsing this forum: Baidu [Spider] and 39 guests
