library updateing
zingo1
Post Thu Mar 05, 2015 2:17 pm
library updateing
OS 10.10.2 yosemite
When i add files serviio updates the library. When I have watched an episode i delete it from within the folder but serviio does not remove it from it`s library.
I have both boxes ticked within library, keep library up to date and search for updates of currently shared files. the latter of which serviio does not seem to be doing.
I have looked i FAQ and quite a few post`s but cant seem to find an answer.
Post Thu Mar 05, 2015 7:34 pm
Re: library updateing
Can you confirm the file is still there by looking in mediabrowser? Just to make sure it's not cached somewhere.
zingo1
Post Fri Mar 06, 2015 1:32 pm
Nothing in media browser. I am removing episodes from within the folder.
If a folder contains 20 episodes and i have watched 10 and then delete 10 there is only ten left to watch.
But when i open serviio on the tv it is still listing all 20 even after a forced refresh and a re boot.
If i try to load any of the 1 to 10 serviio tells me there is no file and goes to episode 11 and plays it.
Serviio knows the file has gone but it hangs on to the image.
Post Fri Mar 06, 2015 2:19 pm
are the files directly in the root of your shared folder?
What folder do you share and what is the file path of the removed file?
zingo1
Post Fri Mar 06, 2015 5:38 pm
yes in root.
mackintosh HD, users, movies, supernatural.
Movies is shared as is supernatural.
Supernatural is a folder within the movies folder which contains the series 1- 20.
Have also found if i rename an episode in a file serviio keeps both but only the renamed is playable.
I can add to the movies folder or supernatural folder no problem and play is ok, it`s just when i delete something serviio keeps the image.
zingo1
Post Sat Mar 07, 2015 7:14 pm
New information. new files show instantly but when you delete a file or movie serviio does not do it instantly there seems to delay as it is now updated a day later and all images have gone of the deleted files.
zingo1
Post Sun Mar 08, 2015 3:03 pm
Sorry to say but i have another issue with this version. The server does not always load i have to go int the terminal and give the command to stop it them the command to start it.
giving the single command to start does not work i have found i need to do both before the sever shows itself.
Not liking this version very much so fare.
Post Sun Mar 08, 2015 4:27 pm
So let's say you have this sturucture:
/user/movies/series_1/episode_1.avi
you should only share (for example)
/user/movies
and not both
/user/movies
Actually, Serviio will not allow you to share them like this (both parent and child folder).
Then if you remove the folder you actually share in the console (eg /user/movies), it will not register the delete event, as Serviio assumes it's only a remote drive being disconnected.
Post Sun Mar 08, 2015 4:31 pm
zingo1 wrote:Sorry to say but i have another issue with this version. The server does not always load i have to go int the terminal and give the command to stop it them the command to start it.
What do you mean does not always load?
zingo1
Post Sun Mar 08, 2015 4:58 pm
Updating, at first only user/movies was shared, library would not update but when i shared series 1 it will update but only on a delayed time.
Server, when i open the console from applications the serviio symbol appears in the task bar but that is all. To get the main window to load i have to stop the server and restart it in the terminal. This is intermittent.
Post Sun Mar 08, 2015 5:36 pm
For the console, try to right-click on the dock icon and select Open console window.
Post Sun Mar 08, 2015 5:37 pm
Also, can you enable detailed logging and post the log here after adding a file to a shared folder?
zingo1
Post Sun Mar 08, 2015 7:04 pm
I cannot enable debug serviio does not appear in application support in library.
Post Sun Mar 08, 2015 8:10 pm
it is there, otherwise you'd not be able to run it.
/Library/Application Support/Serviio
zingo1
Post Mon Mar 09, 2015 12:36 pm
It certainly is not there which is strange. I can send you a screen shot of it if you like.
if i do a search within Application Support it takes me to applications and the console emblem for serviio.
I have totally removed serviio and re installed it. Lets see if it functions ok, but still not listing in Application Support.
Post Mon Mar 09, 2015 10:14 pm
you have to open terminal application and
cd /Library/Application\ Support
ls -al
It should list Serviio among others. Then
cd Serviio/config
Maybe in your Finder it shows your application support (under your User), and not the system one (under root folder)
zingo1
Post Sat Mar 14, 2015 5:12 pm
Ha, since the removal and re install all is functioning Fine.
Users browsing this forum: No registered users and 53 guests
