Subtitles not working
Atilius
Post Thu Jan 12, 2012 7:45 pm
Hi there,
I have a problem with subtitels for P42G30E
It doesnt work for avi files (for no videos) and I have Panasonic Viera profile, I have the same name for file and subtitles, and subs are .srt
Thanks for asisstance.
Martin
voodooo
Post Fri Jan 13, 2012 1:02 pm
Re: Subtitles not working
Have you go to "Options -> subtitles" on the TV and it says no subtitles ? Which kind of files are you playing ?
ppsoglia
Post Sat Jan 21, 2012 11:09 pm
Hi all, i've the same problem with a panasonic g30.
When i play .avi file with srt subs i haven't subs.
Where i'm wrong?
dumen
Post Sat Feb 11, 2012 11:07 am
HI I think i have the same issue. Tv Model is 50ST30A. even though thr movie file name and the subtitle file name is same , ie sample.avi and sample.srt It wont show in the TV. I tried to go to options and subtitles. It says "No subtitles" ... Really worried about this issue.. Is this a problum with the TV ?
Cheers
Post Sat Feb 11, 2012 6:42 pm
which profile are you using ?
have you tried accessing the file for the FOLDER menu rather than MOVIES.
migut
Post Sat Feb 11, 2012 7:31 pm
hi,
same problem here with TX L42E30E. i am using 0.6.2 and standard "panasonic viera" profile
avi + srt subtitles, but they are not visible in options menu... any ideas how we can debug it?
powered by panasonic viera TX-L42E30
dumen
Post Sun Feb 12, 2012 8:20 am
hi Cerberus, Im using new profile called "Panasoniv Viera With AVI support" ... Yes i tried in the Folder menu as well. but no Luck. Is there any other thind ican check ?
Cheers
Post Sun Feb 12, 2012 8:31 am
not currently as it looks like SRT external subs are not supported by the device, but let me confirm this with my helper who has a panasonic device.
PMI - can you test subtitles for me please, i know we activated the feature in the profile but do they work?
dumen
Post Sun Feb 12, 2012 8:49 am
Hi Cerberus,
Thanks for that.. Anyway waiting for your responce..
Cheers
iCO
Post Sun Feb 12, 2012 4:46 pm
dumen wrote:hi Cerberus, Im using new profile called "Panasoniv Viera With AVI support" ... Yes i tried in the Folder menu as well. but no Luck. Is there any other thind ican check ?
Cheers
Hi can you try to play avi and subtitles directly on TV via USB? Can you give more information about avi file? If video codec is dvvideo (divx), the file need to be transcoded and you will have no subtitles.
Post Sun Feb 12, 2012 4:56 pm
Cheers
USB and DLNA can NOT be compared so that test is useless. divx is supported by the device as per my profile, so again thats not an issue.
iCO
Post Sun Feb 12, 2012 5:56 pm
deleted
Post Sun Feb 12, 2012 6:04 pm
iCO wrote:
If subtitles are not supported via USB there are no way for them to work via serviio and DLNA.
Divx is not supported by profile for "ST30 and VT30":
              <Matches container="avi" />
or "Profile for E30, GT30 and UT30"
yes it quite possible for it to work on DLNA even if it doesnt on USB, as they are two completely different systems.
rubbish dvvideo is NOT divx and divx does not have to be in AVI container either.
so please stop posting false information, and quoting a profile at me that i created, trying to say that it proves me wrong.
PMI
Post Sun Feb 12, 2012 7:39 pm
Cerberus wrote:not currently as it looks like SRT external subs are not supported by the device, but let me confirm this with my helper who has a panasonic device.
Best way to test, is to play a video which is supported in its native format, or through USB, with multiple language sound tracks, AND at least one native subtitle track. (verify with VLC player or similar). If while playing the video, the submenu does not show options for switching languages, or subtitles, you are out of luck.
External SRT or any other subtitles are NOT supported on my model, either because it has software for the North-American region, or because my model is the E3, and not the E30. (checked again and verified)
Voodooo has subtitles working on his set, purchased in Europe, and other differences between US and Euro versions. Not the same software version (we checked version numbers).
Subtitles are accessed through the "submenu", and ONLY while playing a video WITH a subtitle track (Note that options which appear in the submenu change depending on the circumstances, meaning, depending on what media or stream the set is playing).
So, if you have the subtitle option in the menu while playing, your set should support subtitles. If you have the option, and the set reports no subtitles found, then they may not have been included when the video was ripped/encoded from the original DVD. (Same thing applies to multiple audio tracks.)
Peter
dumen
Post Mon Feb 13, 2012 1:25 am
Hi PMI,
Thanks for the advice, I do have the subtitle menu appearing in the TV set under the options meny while playing the avi file. But it says " No subtitles" anyway If i play that file in my PC via VLC or similer,Subtitles are displayed.
Let me catch up again, If you think Subtitle menu is displayed , TV is supporting the srt's .. isnt it?
Model is 50ST30A and Im in Australia.
Cheers
PMI
Post Mon Feb 13, 2012 3:42 am
dumen wrote:Let me catch up again, If you think Subtitle menu is displayed , TV is supporting the srt's .. isnt it?
I believe so, based on what I heard here from voodooo, who also has a model sold outside the US.
Can you display native subtitles in any video that will play with transcoding turned off? Let's say you have an MKV or MP4 file with H.264 video, and at least one subtitle track, can you display that track using your subtitle setting in the submenu?
Unfortunately, no way I can verify this, b/c I do not have that option in the menu. Meaning, in my case, subtitles are sent to the TV, but I have no way to turn them on... :x
edit:
I am not sure if SRT subtitles will just appear in a file being sent to the TV without transcoding. Can you please post the file format, or ffmpeg info, or MediaInfo output(text format) for the file you are trying to play with SRT?
Stay cool down there, ;)
Peter
Post Mon Feb 13, 2012 8:17 am
Be careful with VLC, because this software is very permissive. Its not the case of Panasonic/Sony/etc devices.
You also have to check that your srt file is not exotic.
- UTF-8 encoded
- Preferred no tag
- continuous time stamp
- etc
There is a Tool to check & repair srt files : http://www.videohelp.com/tools/SRTWiz
also check with google:
never tested online repair : http://www.gorissen.info/Pierre/files/SRT_repair.htm
dumen
Post Mon Feb 13, 2012 10:18 pm
Hi PMI and Illico
What a surprise kangarooooo .. Subtitles started to work.
:D
What I did was, As per the link which was provided by Illico copy and paste the srt file to the window on the web page. And save the file as a new file with the same name as the movie file. What I have notice is that the new file is significantly smaller than the original SRT file. But anyway the bottom line is its working now.
Thanks Guys
Cheers
Post Tue Feb 14, 2012 1:08 am
dumen wrote:Hi PMI and Illico
:D
Thanks Guys
Cheers
Can you mark this thread solved.
Post Tue Feb 14, 2012 6:14 am
ok so panasonic are extremely picky on the coding of subs that good to know, but more testing is required me thinks, to find out what models allow subs and what ones dont.
Return to Panasonic
