Subtitles not working
I have a problem with subtitels for P42G30E
It doesnt work for avi files (for no videos) and I have Panasonic Viera profile, I have the same name for file and subtitles, and subs are .srt
Thanks for asisstance.
Martin
dumen wrote:hi Cerberus, Im using new profile called "Panasoniv Viera With AVI support" ... Yes i tried in the Folder menu as well. but no Luck. Is there any other thind ican check ?
Cheers
iCO wrote:dumen wrote:hi Cerberus, Im using new profile called "Panasoniv Viera With AVI support" ... Yes i tried in the Folder menu as well. but no Luck. Is there any other thind ican check ?
Cheers
Hi can you try to play avi and subtitles directly on TV via USB? Can you give more information about avi file? If video codec is dvvideo (divx), the file need to be transcoded and you will have no subtitles.
USB and DLNA can NOT be compared so that test is useless. divx is supported by the device as per my profile, so again thats not an issue.
If subtitles are not supported via USB there are no way for them to work via serviio and DLNA.
Divx is not supported by profile for "ST30 and VT30":
or "Profile for E30, GT30 and UT30"
Cerberus wrote:not currently as it looks like SRT external subs are not supported by the device, but let me confirm this with my helper who has a panasonic device.
dumen wrote:Let me catch up again, If you think Subtitle menu is displayed , TV is supporting the srt's .. isnt it?
Model is 50ST30A and Im in Australia.
dumen wrote:Hi PMI and Illico
What a surprise kangarooooo .. Subtitles started to work.
What I did was, As per the link which was provided by Illico copy and paste the srt file to the window on the web page. And save the file as a new file with the same name as the movie file. What I have notice is that the new file is significantly smaller than the original SRT file. But anyway the bottom line is its working now.
Thanks Guys
Cheers
