Linux Daemon scripts
Morcegolas
Post Wed Jan 18, 2012 11:54 am
Re: Linux Daemon scripts
Cereberus,
Hi, I already added as a StartUp Application, but if it's not root doesn't work...
:S
Post Wed Jan 18, 2012 12:24 pm
doessnt have to be root.
Cantello
Post Sun Feb 05, 2012 5:43 pm
What exactly should I add in order to run kairoh's webUI together with serviio at system start on my Ununtu system? Currently I have the serviio daemon started via the scripts presented here but I have no clue on how to integrate the webUI. The wrapper is not supposed to be compatible with serviio as a service, which i what I'm using now so this probably won't work.
Any hints?
Thanks,
Helge.
Post Sun Feb 05, 2012 7:54 pm
Cantello wrote:What exactly should I add in order to run kairoh's webUI together with serviio at system start on my Ununtu system? Currently I have the serviio daemon started via the scripts presented here but I have no clue on how to integrate the webUI. The wrapper is not supposed to be compatible with serviio as a service, which i what I'm using now so this probably won't work.
Any hints?
Thanks,
Helge.
http://wiki.serviio.org/doku.php?id=how ... all:ubuntu
Cantello
Post Mon Feb 06, 2012 9:25 am
Cerberus wrote:http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu
Ok, this works. Thanks! I thought that as this is a service, I cannot use the wrapper and somehow have to use a separate command to start the webUI.
Helge.
tibiscum
Post Fri Apr 20, 2012 3:04 pm
Many thanks to you:
Petr Nejedly - Serviio Developer
AcidumIrae | Web UI for Serviio
Mark Pemberton | Web UI for Serviio
Qkxy | for SuSE Linux - demon configuration
Your work is great !
My config: SuSE Linux 11.3 / Apache 2 Web Server - Renderer: SamsungTV UE37D6500
All stuff works from from first try !
Thanks all of you !
es2burn
Post Mon Aug 13, 2012 1:22 am
Adding a contribution of mine as I'm trying to setup autostart of serviio in Lubuntu 12.04 platform and found the solution after searching online:
sudo text edit "/etc/xdg/lxsession/Lubuntu/autostart" in terminal
and add the following:
@/path/to/serviio/bin/serviio.sh
Note the above /path/to/serviio/ is your actual path to where serviio is unpacked
courtesy to the ubuntu forum thread below:
http://ubuntuforums.org/showthread.php?t=1604211&page=2
Fe14
Post Wed Sep 05, 2012 4:36 pm
I want to remove completely Serviio from my Ubuntu, 'cause i wan't to reinstall it (Serviio doesn't work correctly).
How i can do this?
Post Wed Sep 05, 2012 9:16 pm
just remove the serviio folder
escape.key
Post Sun Nov 18, 2012 7:38 pm
After dealing around with a lot of up and downgrade between versions due to the issue that my Bravia doesn't like Serviio 1.0.1 anymore, I had to switch back and forth between versions.
I have looked to a init script which would fit my needs to be more dynamic on CentOS. Couldn't find one and it's maybe hidden in some section here. However, the pasted init script will work on RedHat based systems and does include the WebUI wrapper also. Feel free to grab it, modify and comment on it.
#!/bin/bash
# serviio
# chkconfig: 235 99 10
# description: Serviio is a DNLA media server\
#    By Roger Beck - 2012
# processname: serviio.sh
### BEGIN INIT INFO
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 2 3 5
# Default-Stop: 0 1 6
# Description: Start or stop the Serviio server
### END INIT INFO
version="0.6.2"
bin_path="/usr/local/serviio-$version/bin"
ui_bin="serviio-webui.sh"
start=$bin_path/serviio.sh
stop=$bin_path/stop
lockfile=/var/lock/subsys/serviio
name='Serviio'
start() {
        $start & >/dev/null 2>&1 </dev/null
        echo "Starting Serviio $version DNLA server"
        RETVAL=$?
        if [ "$RETVAL" = "0" ]; then
                touch $lockfile >/dev/null 2>&1
        fi
        if [ -e $bin_path/$ui_bin ] ; then
                echo "Starting Web-UI on port 8123"
                $bin_path/$ui_bin &
        fi
stop() {
        #$stop
        RETVAL=$?
        serv_kill=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
        java_kill=`ps aux | grep java | grep -v grep | awk '{print $2}'`
        if [ "$serv_kill" = "" ]; then
                echo "Serviio is not running"
                RETVAL=1
        else
                kill $serv_kill
                RETVAL=0
        fi
        if [ "$java_kill" = "" ]; then
                echo "Java is not running"
                RETVAL=1
        else
                kill -9 $java_kill
                RETVAL=0
        fi
        # check is the WebUI wrapper is running
        ui_pid=`ps aux | grep $ui_bin | grep -v grep | awk '{print $2}'`
        if [ "$ui_pid" = "" ]; then
                echo "Serviio WebUI is not running"
        else
                kill $ui_pid
        fi
status() {
        serv_pid=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
        java_pid=`ps aux | grep java | grep -v grep | awk '{print $2}'`
        if [ "$serv_pid" != "" ]; then
                echo "$name (pid $serv_pid) is running"
                RETVAL=0
        else
                echo "$name is stopped"
                RETVAL=1
        fi
        ui_pid=`ps aux | grep serviio-webui | grep -v grep | awk '{print $2}'`
        else
                echo "WebUI (pid $ui_pid) is running"
        fi
restart() {
        stop
        start
        RETVAL=$?
case "$1" in
        start|stop|restart|status)
                $1
                echo $"Usage: $0 {start|stop|status|restart}"
                exit 1
esac
exit $RETVAL
soundcheck
Post Thu Dec 20, 2012 10:05 am
Hi.
I created a serviio.conf upstart script under /etc/init under Ubuntu 12.04/10.
This way you might get rid of all this old fashioned init.d stuff.
#!upstart
description "Serviio Server Upstart script"
env USER=serviio
start on started networking
start on mounted DEVICE=[/UL]*
stop  on shutdown
respawn
exec start-stop-daemon --start --make-pidfile --pidfile /var/run/serviio.pid -c $USER --exec /usr/share/serviio/bin/serviio.sh
Note: You need to create a user "serviio" first!!!
This user will be a kind of system user without login shell, exclusively used for serviio.
E.g.:
 sudo useradd  -u 999 -g nogroup -b /usr/share/serviio -s /bin/false serviio
You also need to change the installation folder/subfolder ownerships. Otherwise you'll get serious permission problems:
sudo chown -R serviio /usr/share/serviio
serviio can now also be manually started/stopped with:
sudo service serviio stop
sudo service serviio start
If you guys can live with above we could/should add it to the Wiki. The "serviio" user generation and startup part is IMO missing anyhow.
Cheers
Post Thu Dec 20, 2012 10:49 am
soundcheck wrote:If you guys can live with above we could/should add it to the Wiki. The "serviio" user generation and startup part is IMO missing anyhow.
Please do.
soohyun2222
Post Sun Jan 06, 2013 12:56 am
thanks for the escape key for posting CentOS script.
they work wonderful!
However, it is to keep in mind that this only starts servillo host.
Additionally, for noobs like me who wonder how to incorporate this script into your computer,
I found this site really useful:
http://articles.slicehost.com/2009/2/2/ ... nit-script
Just substitute nginx to serviio when you follow the steps.
DeanoX
Post Tue Jan 15, 2013 1:26 pm
Thanks to everyone who has contributed. I have used several bits from this thread for my startup script for Zyxel NAS.
Zyxel NSA325 running Serviio 1.1 | Sony Bravia 2011 KDL-24EX320 / KDL-40EX723
Onizyka
Post Mon Jun 24, 2013 7:57 pm
for Debian 6.0
nano /etc/init.d/serviio
#! /bin/sh
 # /etc/init.d/serviio
 ### BEGIN INIT INFO
 # Provides: serviio
 # Default-Start: 3 5
 # Default-Stop: 0 1 2 6
 # Description: Start the serviio DLNA server in headless mode
 ### END INIT INFO
 SERVIIO_HOME="/etc/serviio"
 SERVIIO_DAEMON="serviio.sh"
 SERVIIO_BIN="$SERVIIO_HOME/bin/$SERVIIO_DAEMON"
 SERVIIO_USER="root"
 # Source function library.
 . /lib/lsb/init-functions
 RETVAL=0
 check() {
         # Check that we're a privileged user
         [ $(id -u) = 0 ] || exit 4
         # Check if SERVIIO_HOME exists
         test -d "$SERVIIO_HOME" || exit 5
         # Check if SERVIIO_BIN is executable
         test -x "$SERVIIO_BIN" || exit 5
 start() {
         check
         echo -n "Starting Serviio DLNA server: "
         /usr/bin/sudo -u $SERVIIO_USER -H $SERVIIO_BIN -headless &
         RETVAL=$?
         if [ $RETVAL -eq 0 ]; then
             touch /var/lock/serviio
             log_end_msg 0
         else
             log_end_msg 1
         fi
         echo
         return $RETVAL
 stop() {
         check
         echo -n "Shutting down Serviio DLNA daemon: "
         killproc "$SERVIIO_BIN"
         RETVAL=$?
         [ $RETVAL -eq 0 ] && rm -f /var/lock/serviio
         echo
         return $RETVAL
 restart() {
         stop
         start
 case "$1" in
 start)
         start
 stop)
         stop
 force-reload)
         restart
 restart)
         restart
 condrestart)
         if [ -f /var/lock/serviio ]; then
             restart
         fi
 status)
         status serviio.sh
         echo $"Usage: $0 {start|stop|status|restart|condrestart|force-reload}"
         RETVAL=2
 esac
 exit $RETVAL
chmod a+rx /etc/init.d/serviio
thenamelessthing
Post Thu Mar 13, 2014 5:08 pm
Hi, very nice info! and it's working for me under ubuntu 12.04.
It is possible to add to this upstart script status info? I'm not familiar with this part and I don't know how to do that. A little helping hand for this would be really appreciated...
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
akasaka
Post Thu Aug 28, 2014 11:40 am
Hey Guys,
Updated this for Ubuntu 14.04 but should work on other Debian based systems.
/etc/int.d/serviio
#!/bin/bash
#- Daemon Script Configuration for Serviio Media Server
#- By Ian Laird; converted for Debian by Jacob Lundberg
#- Updated and Merged for Ubuntu 14.04 by Matthew Bate
### BEGIN INIT INFO
# Provides:          serviio
# Required-Start:    $local_fs $remote_fs $network $syslog
# Required-Stop:     $local_fs $remote_fs $network $syslog
# Default-Start:     2 3 4 5
# X-Interactive:     true
# Short-Description: Start/stop serviio media server
# Description:       The Serviio media server makes your media available to
#                    all kinds of networked devices.
### END INIT INFO
if [ -f /etc/default/rcS ]; then
        . /etc/default/rcS
fi
NAME="Serviio Media Server"
DAEMON="/opt/Serviio/bin/serviio.sh"      ## Update this to point at pc5dczc_root/bin/serviio.sh
DAEMON_STOP=" -stop"
SERVICE_ACCOUNT="root"            ## DON'T RUN UNDER ROOT!
TIMEOUT=3
# We have this because start-stop-daemon needs one and wont start without it.  Although it provides wrong PID ID of Java Client.
PIDFILE="/var/run/serviiod.pid"
if [ -f /etc/default/serviio ]; then
        . /etc/default/serviio
fi
[ -x "$DAEMON" ] || exit 0
#  Status function check not only the PID file but if it has gone missing it will look for the Java Client manually.
status() {
    if [ $1 = "PID" ]; then
   if [ ! -f $TPIDFILE ]; then
       PID=$(ps -ef | grep "org.serviio.MediaServer" | grep -v grep | awk "{ print \$2 }")
       echo $PID
   else
       PID=$(cat $TPIDFILE)
          echo $PID
   fi
    else
        if [[ -z $PID ]]; then
            if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently offline."; else echo "0"; fi # Offline
        else
          if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently online."; else echo "1"; fi # Online
        fi
    fi
start() {
    RUNNING=$(status "0")
    if [ $RUNNING = "0" ]; then
   log_daemon_msg "Starting Serviio Media Server..."
   start-stop-daemon --start -q -b -p "$PIDFILE" -m -c "${SERVICE_ACCOUNT}" -x "${DAEMON}"
   log_end_msg $?
    else
   log_daemon_msg "Serviio Media Server is already running."
   log_end_msg 1
    fi
stop() {
    if [ ${#RUNNING} = "1" ]; then
   log_daemon_msg "Shutting Down Serviio Media Server..."
   ${DAEMON} ${DAEMON_STOP}
   log_end_msg $?
    else
   log_daemon_msg "Serviio Media Server is already shutdown."
   log_end_msg 1
    fi
force_stop() {
   RUNNING=$(status "PID")
   kill -TERM $RUNNING
   log_end_msg $?
    else
   log_end_msg 1
    fi
case "${1:-}" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        status)
                status $1
   force-stop)
      force_stop
                log_success_msg "Usage: /etc/init.d/$NAME {start|stop|force-stop|restart|status}"
                exit 1
esac
exit 0
I've included credits based on where this originally started from but I'm pretty sure I've destroyed the code from the original authors anyways (First Page of Thread).
ehrepli
Post Sun Dec 28, 2014 7:26 pm
Hi guys
I'm running Serviio on a headless Ubuntu server. All my files are located on a NAS, which is NFS mounted on the server and then served onto my devices.
My main issue so far is with the library updates. Whenever there is a power issue in my area, both my server and NAS go down when the UPS is out of juice.
When power is back up, NAS and server boot, but usually the NAS is slower, and by the time the server tries to mount the disk via NFS, it fails, since the NAS is still booting.
Then Serviio starts, does not detect any file and clears the database. When I manually remount the NAS disk, Serviio starts reindexing everything, which usually takes a few hours.
I've done an upstart script for Serviio that checks if the mounted folder is available and if not, does not start Serviio.
I've also created a simple script that runs every minute and if the folder is unavailable, stops the Serviio service, so that the database does not update.
I realize this solution is tailored for my specific needs, and that in the event of an issue as described above, it requires human intervention, but that works for me. All i try to do is stop the database refresh when the files are not there. I could stop the automatic refresh from the serviio console, but the family add new files everyday and I don't want to manually refresh every time.
I've used the upstart script provided by soundcheck in this same post (posting.php?mode=reply&f=17&t=71#pr58712), and modified it to my needs. I post it here in case it can be of use to someone.
create a file /etc/init/serviio.conf
#!upstart
# script will run only after network is up and my /media/nas mounted
start on (started networking and mounted MOUNTPOINT=/media/nas)
#optional stuff
description "Serviio Server Upstart Script"
# configuration variables
#user that will run the Serviio service
env USER=ale
#the folder that contains all my movies
env FOLDER=/media/nas/videos
#a file in the folder above
env FPID=.serviio.pid
#path to the serviio start script
env BIN=/path/to/your_serviio/bin/serviio.sh
# pre-start stanza
pre-start script
  # main process will not be run if /some/file does not exist
 # if the file defined above does not exist (folder not mounted) it will exit
  test -f $FOLDER/$FPID || { stop ; exit 0; }
end script
# normal script
script
   # Set up correct LANG // you might not need this
   if [ -r /etc/default/locale ]; then
       . /etc/default/locale
       export LANG LANGUAGE LC_MESSAGES LC_ALL LC_CTYPE
   fi
   #start the service
   exec start-stop-daemon --start --make-pidfile --pidfile /var/run/serviio.pid -c $USER --exec $BIN
end script
In my case, i'm running serviio with my own user which i'm sure is the wrong thing to do. You can create a dedicated user following soundcheck's post (posting.php?mode=reply&f=17&t=71#pr58712)
Now you run
sudo initctl reload-configuration
If I reboot, my script will run after network is up and my folder is mounted.
Now i want to add another checkpoint in case my NAS goes down for any reason.
To do this I created a simple bash script and scheduled it with cron.
Create a file called test_serviio.sh
#!/bin/bash
# this is the file to check
FPID=/media/nas/videos/.serviio.pid
if [ ! -f $FPID ]
then
    echo "File not found: "$FPID
    echo "The system tried to stop Serviio service to keep the database unrefreshed at "$(date)" because "$FPID" was not available. You will need to restart the service manually, but first make sure that "$FPID" is available again." | mail -s "Serviio service stopped" you@yourmail.com
fi
I have scheduled it in the root crontab to run every minute. It's very rudimentary but gets the work done.
One small issue is that if the NAS goes down, it will send me a mail every minute for as long as the disk is not remounted. But well...
As you can see from the above, i'm a linux newbie, can't program at all, but hey, seems to work. Hoping that this could help some people.
Post Sun Dec 28, 2014 7:56 pm
Cool. 1.5 will come with a new way to handle remote drives and the library will not be wiped out anymore if the drive is not available on startup.
Sheriff Hobbes
Post Fri Mar 06, 2015 10:49 pm
I want to share my service script /etc/init.d/serviio for my Serviio 1.5.1 installation on CentOS 7.0 .
It's the one from the Wiki for CentOS 6.3 with little modifications to the "stop" function.
#! /bin/sh
# chkconfig 35 85 15
# description: Start the serviio DLNA server in headless mode
### BEGIN INIT INFO
# Provides: serviio
### END INIT INFO
SERVIIO_HOME="/opt/serviio"
SERVIIO_USER="serviio"
. /etc/rc.d/init.d/functions
RETVAL=0
check() {
start() {
        check
   /bin/su --session-command="$SERVIIO_BIN -headless" $SERVIIO_USER &
        RETVAL=$?
            touch /var/lock/subsys/serviio.sh
            echo_success
        else
            echo_failure
        fi
        echo
        return $RETVAL
stop() {
    check
    # Retrieve JAVA Serviio process ID
    PIDDAEMON=`pgrep -f "/bin/su --session-command=$SERVIIO_BIN -headless"`
    [ -z "$PIDDAEMON" ] || PIDJAVA=`ps -o pid= --ppid $PIDDAEMON`
    # Kill the daemon
    kill "$PIDDAEMON"
    RETVAL=$?
    [ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/serviio.sh
    echo
    # Kill the JAVA Serviio process if exists
    [ -z "$PIDJAVA" ] || kill -9 $PIDJAVA
    return $RETVAL
restart() {
        stop
        start
case "$1" in
start)
        start
stop)
        stop
force-reload)
        restart
restart)
        restart
condrestart)
        if [ -f /var/lock/subsys/serviio.sh ]; then
            restart
        fi
status)
        status serviio.sh
        RETVAL=2
esac
exit $RETVAL
Thanks,
SH
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
