Re: Linux Daemon scripts
Hi, I already added as a StartUp Application, but if it's not root doesn't work...
:S
Cantello wrote:What exactly should I add in order to run kairoh's webUI together with serviio at system start on my Ununtu system? Currently I have the serviio daemon started via the scripts presented here but I have no clue on how to integrate the webUI. The wrapper is not supposed to be compatible with serviio as a service, which i what I'm using now so this probably won't work.
Any hints?
Thanks,
Helge.
Cerberus wrote:http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu
#!/bin/bash
# serviio
# chkconfig: 235 99 10
# description: Serviio is a DNLA media server\
# By Roger Beck - 2012
# processname: serviio.sh
### BEGIN INIT INFO
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 2 3 5
# Default-Stop: 0 1 6
# Description: Start or stop the Serviio server
### END INIT INFO
version="0.6.2"
bin_path="/usr/local/serviio-$version/bin"
ui_bin="serviio-webui.sh"
start=$bin_path/serviio.sh
stop=$bin_path/stop
lockfile=/var/lock/subsys/serviio
name='Serviio'
start() {
$start & >/dev/null 2>&1 </dev/null
echo "Starting Serviio $version DNLA server"
RETVAL=$?
if [ "$RETVAL" = "0" ]; then
touch $lockfile >/dev/null 2>&1
fi
if [ -e $bin_path/$ui_bin ] ; then
echo "Starting Web-UI on port 8123"
$bin_path/$ui_bin &
fi
stop() {
#$stop
RETVAL=$?
serv_kill=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
java_kill=`ps aux | grep java | grep -v grep | awk '{print $2}'`
if [ "$serv_kill" = "" ]; then
echo "Serviio is not running"
RETVAL=1
else
kill $serv_kill
RETVAL=0
fi
if [ "$java_kill" = "" ]; then
echo "Java is not running"
RETVAL=1
else
kill -9 $java_kill
RETVAL=0
fi
# check is the WebUI wrapper is running
ui_pid=`ps aux | grep $ui_bin | grep -v grep | awk '{print $2}'`
if [ "$ui_pid" = "" ]; then
echo "Serviio WebUI is not running"
else
kill $ui_pid
fi
status() {
serv_pid=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
java_pid=`ps aux | grep java | grep -v grep | awk '{print $2}'`
if [ "$serv_pid" != "" ]; then
echo "$name (pid $serv_pid) is running"
RETVAL=0
else
echo "$name is stopped"
RETVAL=1
fi
ui_pid=`ps aux | grep serviio-webui | grep -v grep | awk '{print $2}'`
else
echo "WebUI (pid $ui_pid) is running"
fi
restart() {
stop
start
RETVAL=$?
case "$1" in
start|stop|restart|status)
$1
echo $"Usage: $0 {start|stop|status|restart}"
exit 1
esac
exit $RETVAL
soundcheck wrote:If you guys can live with above we could/should add it to the Wiki. The "serviio" user generation and startup part is IMO missing anyhow.
#! /bin/sh
# /etc/init.d/serviio
### BEGIN INIT INFO
# Provides: serviio
# Default-Start: 3 5
# Default-Stop: 0 1 2 6
# Description: Start the serviio DLNA server in headless mode
### END INIT INFO
SERVIIO_HOME="/etc/serviio"
SERVIIO_DAEMON="serviio.sh"
SERVIIO_BIN="$SERVIIO_HOME/bin/$SERVIIO_DAEMON"
SERVIIO_USER="root"
# Source function library.
. /lib/lsb/init-functions
RETVAL=0
check() {
# Check that we're a privileged user
[ $(id -u) = 0 ] || exit 4
# Check if SERVIIO_HOME exists
test -d "$SERVIIO_HOME" || exit 5
# Check if SERVIIO_BIN is executable
test -x "$SERVIIO_BIN" || exit 5
start() {
check
echo -n "Starting Serviio DLNA server: "
/usr/bin/sudo -u $SERVIIO_USER -H $SERVIIO_BIN -headless &
RETVAL=$?
if [ $RETVAL -eq 0 ]; then
touch /var/lock/serviio
log_end_msg 0
else
log_end_msg 1
fi
echo
return $RETVAL
stop() {
check
echo -n "Shutting down Serviio DLNA daemon: "
killproc "$SERVIIO_BIN"
RETVAL=$?
[ $RETVAL -eq 0 ] && rm -f /var/lock/serviio
echo
return $RETVAL
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
force-reload)
restart
restart)
restart
condrestart)
if [ -f /var/lock/serviio ]; then
restart
fi
status)
status serviio.sh
echo $"Usage: $0 {start|stop|status|restart|condrestart|force-reload}"
RETVAL=2
esac
exit $RETVAL
#!/bin/bash
#- Daemon Script Configuration for Serviio Media Server
#- By Ian Laird; converted for Debian by Jacob Lundberg
#- Updated and Merged for Ubuntu 14.04 by Matthew Bate
### BEGIN INIT INFO
# Provides: serviio
# Required-Start: $local_fs $remote_fs $network $syslog
# Required-Stop: $local_fs $remote_fs $network $syslog
# Default-Start: 2 3 4 5
# X-Interactive: true
# Short-Description: Start/stop serviio media server
# Description: The Serviio media server makes your media available to
# all kinds of networked devices.
### END INIT INFO
if [ -f /etc/default/rcS ]; then
. /etc/default/rcS
fi
NAME="Serviio Media Server"
DAEMON="/opt/Serviio/bin/serviio.sh" ## Update this to point at pc5dczc_root/bin/serviio.sh
DAEMON_STOP=" -stop"
SERVICE_ACCOUNT="root" ## DON'T RUN UNDER ROOT!
TIMEOUT=3
# We have this because start-stop-daemon needs one and wont start without it. Although it provides wrong PID ID of Java Client.
PIDFILE="/var/run/serviiod.pid"
if [ -f /etc/default/serviio ]; then
. /etc/default/serviio
fi
[ -x "$DAEMON" ] || exit 0
# Status function check not only the PID file but if it has gone missing it will look for the Java Client manually.
status() {
if [ $1 = "PID" ]; then
if [ ! -f $TPIDFILE ]; then
PID=$(ps -ef | grep "org.serviio.MediaServer" | grep -v grep | awk "{ print \$2 }")
echo $PID
else
PID=$(cat $TPIDFILE)
echo $PID
fi
else
if [[ -z $PID ]]; then
if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently offline."; else echo "0"; fi # Offline
else
if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently online."; else echo "1"; fi # Online
fi
fi
start() {
RUNNING=$(status "0")
if [ $RUNNING = "0" ]; then
log_daemon_msg "Starting Serviio Media Server..."
start-stop-daemon --start -q -b -p "$PIDFILE" -m -c "${SERVICE_ACCOUNT}" -x "${DAEMON}"
log_end_msg $?
else
log_daemon_msg "Serviio Media Server is already running."
log_end_msg 1
fi
stop() {
if [ ${#RUNNING} = "1" ]; then
log_daemon_msg "Shutting Down Serviio Media Server..."
${DAEMON} ${DAEMON_STOP}
log_end_msg $?
else
log_daemon_msg "Serviio Media Server is already shutdown."
log_end_msg 1
fi
force_stop() {
RUNNING=$(status "PID")
kill -TERM $RUNNING
log_end_msg $?
else
log_end_msg 1
fi
case "${1:-}" in
start)
start
stop)
stop
restart)
stop
start
status)
status $1
force-stop)
force_stop
log_success_msg "Usage: /etc/init.d/$NAME {start|stop|force-stop|restart|status}"
exit 1
esac
exit 0
#!upstart
# script will run only after network is up and my /media/nas mounted
start on (started networking and mounted MOUNTPOINT=/media/nas)
#optional stuff
description "Serviio Server Upstart Script"
# configuration variables
#user that will run the Serviio service
env USER=ale
#the folder that contains all my movies
env FOLDER=/media/nas/videos
#a file in the folder above
env FPID=.serviio.pid
#path to the serviio start script
env BIN=/path/to/your_serviio/bin/serviio.sh
# pre-start stanza
pre-start script
# main process will not be run if /some/file does not exist
# if the file defined above does not exist (folder not mounted) it will exit
test -f $FOLDER/$FPID || { stop ; exit 0; }
end script
# normal script
script
# Set up correct LANG // you might not need this
if [ -r /etc/default/locale ]; then
. /etc/default/locale
export LANG LANGUAGE LC_MESSAGES LC_ALL LC_CTYPE
fi
#start the service
exec start-stop-daemon --start --make-pidfile --pidfile /var/run/serviio.pid -c $USER --exec $BIN
end script
#!/bin/bash
# this is the file to check
FPID=/media/nas/videos/.serviio.pid
if [ ! -f $FPID ]
then
echo "File not found: "$FPID
service serviio stop
echo "The system tried to stop Serviio service to keep the database unrefreshed at "$(date)" because "$FPID" was not available. You will need to restart the service manually, but first make sure that "$FPID" is available again." | mail -s "Serviio service stopped" you@yourmail.com
fi
#! /bin/sh
# chkconfig 35 85 15
# description: Start the serviio DLNA server in headless mode
### BEGIN INIT INFO
# Provides: serviio
### END INIT INFO
SERVIIO_HOME="/opt/serviio"
SERVIIO_USER="serviio"
. /etc/rc.d/init.d/functions
RETVAL=0
check() {
start() {
check
/bin/su --session-command="$SERVIIO_BIN -headless" $SERVIIO_USER &
RETVAL=$?
touch /var/lock/subsys/serviio.sh
echo_success
else
echo_failure
fi
echo
return $RETVAL
stop() {
check
# Retrieve JAVA Serviio process ID
PIDDAEMON=`pgrep -f "/bin/su --session-command=$SERVIIO_BIN -headless"`
[ -z "$PIDDAEMON" ] || PIDJAVA=`ps -o pid= --ppid $PIDDAEMON`
# Kill the daemon
kill "$PIDDAEMON"
RETVAL=$?
[ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/serviio.sh
echo
# Kill the JAVA Serviio process if exists
[ -z "$PIDJAVA" ] || kill -9 $PIDJAVA
return $RETVAL
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
force-reload)
restart
restart)
restart
condrestart)
if [ -f /var/lock/subsys/serviio.sh ]; then
restart
fi
status)
status serviio.sh
RETVAL=2
esac
exit $RETVAL
