Sony Bravia 2011 Series
Post Thu Mar 01, 2012 6:31 am
Re: Sony Bravia 2011 Series
Could you also post MediaInfo result of the same files ?
koan00
Post Fri Mar 02, 2012 1:16 am
Requested Info is below. I should also mention they are both visible and both play fine on my Samsung C series TV too, not just the DirecTV DVRs. It just weird that they don't even show up on the Sony. Another oddity is I recall at some point I could see avi's, but now I can't. I have completely reinstalled serviio from scratch and still nothing. Could this be an issue with ffmpeg? That's the only other thing I feel might have changed between now and when I last recall it working.
Complete name                            : Y:\Video\Curious George\Curious George 1.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 313 MiB
Duration                                 : 14mn 58s
Overall bit rate                         : 2 927 Kbps
Writing application                      : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library                          : VirtualDubMod build 2178/release
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : No
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Custom
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 14mn 58s
Bit rate                                 : 2 728 Kbps
Width                                    : 720 pixels
Height                                   : 544 pixels
Display aspect ratio                     : 4:3
Bits/(Pixel*Frame)                       : 0.291
Stream size                              : 292 MiB (93%)
Writing library                          : XviD 1.2.0.dev47 (UTC 2006-11-01)
Format profile                           : Dolby Digital
Codec ID                                 : 2000
Duration                                 : 14mn 57s
Bit rate                                 : 192 Kbps
Stream size                              : 20.6 MiB (7%)
Alignment                                : Split accross interleaves
Interleave, duration                     : 96 ms (2.30 video frames)
Interleave, preload duration             : 96 ms
Complete name                            : Y:\Video\Curious George\Curious.George.2.Follow.That.Monkey.2009.avi
Format                                   : AVI
File size                                : 700 MiB
Duration                                 : 1h 16mn
Overall bit rate                         : 1 274 Kbps
Writing application                      : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                          : VirtualDubMod build 2540/release
Format settings, BVOP                    : 2
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : XVID
Duration                                 : 1h 16mn
Bit rate                                 : 1 126 Kbps
Width                                    : 624 pixels
Height                                   : 352 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.205
Stream size                              : 618 MiB (88%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 16mn
Bit rate                                 : 136 Kbps
Stream size                              : 74.4 MiB (11%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.60 video frame)
Interleave, preload duration             : 287 ms
Writing library                          : LAME3.90
Encoding settings                        : -m j -V 0 -q 0 -lowpass 19.5 --vbr-new
koan00
Post Fri Mar 02, 2012 9:57 pm
Getting a bit farther here. Check out the results for protocol info. I dont see 'avi' anywhere in there. I do have auto firmware updates enabled for the TV. I wonder if it updated to a firmware that dropped AVI support. Any advice?
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-mp2t-mphl-188:*,http-get:*:image/jpeg:*,http-get:*:audio/mpeg:*,http-get:*:audio/L16:*,http-get:*:audio/x-ms-wma:*,http-get:*:video/mpeg:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mp4:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-asf:*
NX3
Post Sat Mar 03, 2012 5:18 pm
If you select the Sony 2010 are the files listed ?
koan00
Post Sun Mar 04, 2012 1:19 pm
NX3 wrote:If you select the Sony 2010 are the files listed ?
Yes, they are listed when manually selecting the 2010 profile.
NX3
Post Sun Mar 04, 2012 4:57 pm
koan00 wrote:Yes, they are listed when manually selecting the 2010 profile.
That will have to be your work around as for some strange reason your set doesn't support native AVI playback over DLNA.
koan00
Post Sun Mar 04, 2012 7:20 pm
So if I'm reading the profile correctly, the only difference in the 2010 and 2011 profiles is that for 2010, the follow formats are transconded?
avi/msmpeg4
avi/mjpeg
avi/mpeg4
Post Sun Mar 04, 2012 7:34 pm
According to GetProtocolinfo result of your NX720 US version, this device does not support avi/divx/msvideo codec, like 2010 models.
So, yes, all avi files will be transcoded.
Yes, select on serviio console 2010 model profile.
This is the same result for some 2011 models : HX729, HX925, HX929,etc
http://wiki.serviio.org/doku.php?id=dev ... at_support
Lowlander
Post Sat Mar 24, 2012 6:01 pm
Hi there,
I had experienced a jerky playback back in 0.5.x, where at the beginning of quite a lot of my files (mkv/avc/aac) frames kept jumping back and forth, to pick up smooth playback after about 10 seconds. I was very pleased to see that this nasty effect was gone in 0.6, but from 0.6.2 I had to revert back to 0.6 as soon as I found that the very same files played jerky again with 0.6.2.
Now I gave 0.6.2 another try the other day and think those online streaming features are extremely sexy. 8-) Brilliant work, guys!
If it weren't for those jumpy frames when playing back my files... Has anyone with a 2011 Bravia experienced those playback probs? I'd very much like to stick with 0.6.2 this time and HAVE to get around this.
(I can provide a short sample through Dropbox if someone is willing to throw it against his Bravia.)
Thx
Low
koan00
Post Thu Mar 29, 2012 12:52 pm
I am mot having any jerkisness. Maybe the first 1-2 seconds for a transcoded file, but thats it and doesnt bother me at all.
PM the dropbox link and I can test your file if you like.
Post Thu Mar 29, 2012 6:43 pm
koan00 wrote:PM the dropbox link and I can test your file if you like.
+1
Post Fri Mar 30, 2012 7:02 pm
I tested your PM mkv file.
Sony Bravia 2010 TV: transcoded in MPEGTS container and result is good.
BDP-S373 : remuxed in MPEGTS container and result is good.
its a low AVC-H264 video bitrate around 1Mbps with 5Mbps peek, but video looks good.
At Which time have you a problem, and could you explain the problem?
Do you have another ffmpeg process (library refresh) ?
koan00
Post Sun Apr 01, 2012 7:18 pm
I tested the file and see the same jerky behavior you mentioned. Plays fine in VLC.
I am using a 2011 TV with 2010 profile.
mattb
Post Sun Apr 15, 2012 1:27 am
Illico wrote:According to GetProtocolinfo result of your NX720 US version, this device does not support avi/divx/msvideo codec, like 2010 models.
I have a 46HX729, and I can't browse AVI files either. But, I added AVI to the section:
<!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
<!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
And transcoding works, kind of a bummer though. I found this document which might be enlightening:
http://esupport.sony.com/US/perl/suppor ... KDL46HX729
Lowlander
Post Mon Apr 16, 2012 3:36 pm
Guys,
Thanks for testing my file!
koan00 wrote:I tested the file and see the same jerky behavior you mentioned.
Good to know I'm not alone. :roll:
Illico wrote:Sony Bravia 2010 TV: transcoded in MPEGTS container and result is good.
From the beginning of playback (mkv/avc/aac) frames keep jumping back and forth, to pick up smooth playback after about 10 seconds, while sound plays fine right away. This nasty effect, introduced to me with Serviio 0.5, had gone in Serviio 0.6, but from 0.6.2 it's back. There is no other ffmpeg process, and the effect happens each and every time I play back a file of the same (mkv/avc/aac) kind.
I recently found out that (mkv/avc-720p/ac3) is jerky, too. I think it's almost safe to claim that all remuxed videos (with or without transcoded audio) are jerky, while natively played (ts/mpeg2/mp2 from SD DVB) as well as fully transcoded (avi) videos play fine.
From your results I think there may be differences of some kind between 2010 Bravias (as Illico's) and 2011 Bravis (as koan's and mine). What doesn't matter IMHO is whether you use a 2010 or 2011 profile for a 2011 TV, as the difference in profiles just concerns playback of avis.
Have a nice one
Low
Post Mon May 07, 2012 12:09 pm
Sony Bravia 2011 models are supposed to support following format, and with current official profile, all are transcoded:
    ASF files: http-get:*:video/x-ms-asf:*
    WMV files: http-get:*:video/x-ms-wmv:*
    MP4 files: http-get:*:video/mp4:*
I need help of 2011 user to make some tests.
So I will try to find samples for each formats. (I will edit this post with some sample links)
- ASF : elephant.asf(asf, Audio: wmav2, Video: msmpeg4 MP43),
- WMV : asf_with_chapters.wmv (asf,Audio: wmav2, Audio: wmav2, Video: wmv3 WMV3), quicktime.wmv (asf, Video: wmav2), wmv2_new_vlc-issue1637.wmv (asf,Audio: wmav2 , Video: wmv2 (WMV2))
- MP4 : TINTIN Teaser 480p (124079300.mov), 720p (124079301.mov) and 1080p (124079302.mov) (mov,mp4,m4a,3gp,3g2,mj2, Audio: aac (mp4a),Video: h264 (avc1) )
At this point, we could start with that profile, asf and mp4 are commented ( only mp4 with high h264 profile level > 4.1 are kept)
So ASF,WMV and MP4 files should be delivered in native format (please check detailed log file to confirm).
   <Profile id="9" name="Sony Bravia TV (2011)" extendsProfileId="1">
      <!-- same as older Bravia 2010/2009 except it supports AVI playback -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA KDL-\d{2}([A-Z]X\d2\d|CX400).*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <!-- act as WMP so that the TV doesn't show root categories -->
         <ModelName>Windows Media Player Sharing</ModelName>
         <ModelNumber>3.0</ModelNumber>
         <Manufacturer>Microsoft Corporation</Manufacturer>
      </DeviceDescription>
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
         <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
         <!-- <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" forceInheritance="true"> -->
            <!-- <Matches container="asf" vCodec="mpeg2video" /> -->
         <!-- </Video> -->
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="mpegts" vCodec="h264" profile="high" levelGreaterThan="4.1" />
        <Matches container="mpegts" vCodec="h264" profile="main" levelGreaterThan="4.1" />
         <!-- Remux h264 video with AC3 audio to MPEG-TS stream without transcoding -->
         <!-- expected profile AVC_TS_MP_HD_AC3_ISO -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" vCodec="h264" aCodec="ac3" />
            <!-- <Matches container="mp4" vCodec="h264" aCodec="ac3" /> -->
            <Matches container="matroska" vCodec="h264" aCodec="ac3" />
         <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <!-- <Matches container="mp4" vCodec="h264" /> -->
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpegts" aCodec="aac" />
            <Matches container="mpegts" aCodec="mp3" />
            <Matches container="mpegts" aCodec="dca" />
            <Matches container="mpegts" aCodec="lpcm" />
            <Matches container="mpeg" aCodec="dca" />
            <Matches container="ogg" vCodec="mpeg4" />
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192" forceInheritance="true">
            <!-- <Matches container="asf" /> -->
            <!-- <Matches container="mp4" /> -->
            <Matches container="flv" />
            <Matches container="wtv" />
            <Matches container="ogg" />
         <Audio targetContainer="lpcm" forceInheritance="true">
            <!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
_
koan00
Post Mon May 14, 2012 1:05 am
Ok, I have tested. Here are the results:
1) ASF file was not listed for selection for playback.
2) asf_with_chapters.wmv - plays
3) quicktime.wmv , TV reports: "File can not be played"
4) wmv2_new_vlc-issue1637.wmv - plays but all black screen and audio pops
5) All 3 .mov play fine
And ofcourse all AVIs are not shown just like the old profile. This still needs fixing too.
NX3
Post Sat Jan 04, 2014 5:37 pm
I was trying out Plex and noticed they use the Serviio Sony profiles, although on one of my Sony 2011 the profile doesn't work which is annoying.
I got a dump of the latest Intel Spy info from the latest firmware just to see if anything new. I can see ASF, WMV and WMA now listed, not that I use these file formats so not worried.
Anyway FYI latest firmware output...
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;SONY.COM_PN=DTCP_SESF_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_L2_T;SONY.COM_PN=DTCP_SESF_60_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/x-msvideo:*,
http-get:*:video/x-divx:*,
http-get:*:video/divx:*,
http-get:*:video/avi:*,
Post Sun Jan 05, 2014 9:51 am
This the same spy result, http://wiki.serviio.org/doku.php?id=dev ... at_support
So no change with latest firmware.
NX3
Post Sun Jan 05, 2014 12:44 pm
I'd not checked the wiki, just this posting.... all good then :)
Previous
