Re: Sony Bravia 2011 Series
Complete name : Y:\Video\Curious George\Curious George 1.avi
Format : AVI
File size : 313 MiB
Duration : 14mn 58s
Overall bit rate : 2 927 Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDubMod build 2178/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 14mn 58s
Bit rate : 2 728 Kbps
Width : 720 pixels
Height : 544 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.291
Stream size : 292 MiB (93%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : 2000
Duration : 14mn 57s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 20.6 MiB (7%)
Alignment : Split accross interleaves
Interleave, duration : 96 ms (2.30 video frames)
Interleave, preload duration : 96 ms
Language : EnglishGeneral
Complete name : Y:\Video\Curious George\Curious.George.2.Follow.That.Monkey.2009.avi
Format : AVI
File size : 700 MiB
Duration : 1h 16mn
Overall bit rate : 1 274 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Format settings, BVOP : 2
Codec ID : XVID
Duration : 1h 16mn
Bit rate : 1 126 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.205
Stream size : 618 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 16mn
Bit rate mode : Variable
Bit rate : 136 Kbps
Stream size : 74.4 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 287 ms
Writing library : LAME3.90
Encoding settings : -m j -V 0 -q 0 -lowpass 19.5 --vbr-newhttp-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-mp2t-mphl-188:*,http-get:*:image/jpeg:*,http-get:*:audio/mpeg:*,http-get:*:audio/L16:*,http-get:*:audio/x-ms-wma:*,http-get:*:video/mpeg:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mp4:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-asf:*NX3 wrote:If you select the Sony 2010 are the files listed ?
koan00 wrote:Yes, they are listed when manually selecting the 2010 profile.
koan00 wrote:PM the dropbox link and I can test your file if you like.
Illico wrote:According to GetProtocolinfo result of your NX720 US version, this device does not support avi/divx/msvideo codec, like 2010 models.
So, yes, all avi files will be transcoded.
Yes, select on serviio console 2010 model profile.
This is the same result for some 2011 models : HX729, HX925, HX929,etc
http://wiki.serviio.org/doku.php?id=dev ... at_support
koan00 wrote:I tested the file and see the same jerky behavior you mentioned.
Illico wrote:Sony Bravia 2010 TV: transcoded in MPEGTS container and result is good.
BDP-S373 : remuxed in MPEGTS container and result is good.
At Which time have you a problem, and could you explain the problem?
Do you have another ffmpeg process (library refresh) ?
<Profile id="9" name="Sony Bravia TV (2011)" extendsProfileId="1">
<!-- same as older Bravia 2010/2009 except it supports AVI playback -->
<Detection>
<UPnPSearch>
<FriendlyName>BRAVIA KDL-\d{2}([A-Z]X\d2\d|CX400).*</FriendlyName>
</UPnPSearch>
</Detection>
<DeviceDescription>
<!-- act as WMP so that the TV doesn't show root categories -->
<ModelName>Windows Media Player Sharing</ModelName>
<ModelNumber>3.0</ModelNumber>
<Manufacturer>Microsoft Corporation</Manufacturer>
</DeviceDescription>
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
<!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
<!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
<!-- <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" forceInheritance="true"> -->
<!-- <Matches container="asf" vCodec="mpeg2video" /> -->
<!-- </Video> -->
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
<!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
<Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
<Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
<Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
<Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
<Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
<Matches container="mpegts" vCodec="h264" profile="high" levelGreaterThan="4.1" />
<Matches container="mpegts" vCodec="h264" profile="main" levelGreaterThan="4.1" />
<!-- Remux h264 video with AC3 audio to MPEG-TS stream without transcoding -->
<!-- expected profile AVC_TS_MP_HD_AC3_ISO -->
<Video targetContainer="mpegts" forceInheritance="true">
<Matches container="avi" vCodec="h264" aCodec="ac3" />
<!-- <Matches container="mp4" vCodec="h264" aCodec="ac3" /> -->
<Matches container="matroska" vCodec="h264" aCodec="ac3" />
<!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<!-- <Matches container="mp4" vCodec="h264" /> -->
<!-- if audio different to ac3, must be transcoded -->
<Matches container="mpegts" aCodec="aac" />
<Matches container="mpegts" aCodec="mp3" />
<Matches container="mpegts" aCodec="dca" />
<Matches container="mpegts" aCodec="lpcm" />
<Matches container="mpeg" aCodec="dca" />
<Matches container="ogg" vCodec="mpeg4" />
<!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192" forceInheritance="true">
<!-- <Matches container="asf" /> -->
<!-- <Matches container="mp4" /> -->
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="ogg" />
<Audio targetContainer="lpcm" forceInheritance="true">
<!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
<Matches container="flac" />
<Matches container="adts" />
</Audio>
</Profile>http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;SONY.COM_PN=DTCP_SESF_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_L2_T;SONY.COM_PN=DTCP_SESF_60_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/x-msvideo:*,
http-get:*:video/x-divx:*,
http-get:*:video/divx:*,
http-get:*:video/avi:*,
