Can't play .3gp and .dat files on my Sony TV
• Page 1 of 1
Thanks to Serviio, my Sony TV (40CX520) shows .mkv, .flv and etc, but it does not show .3gp and .dat files. Any idea?!
Re: Can't play .3gp and .dat files on my Sony TV
Could you provide information about .3gp and .dat file ? (see signature links) (ffmpeg -i <file> an MediaInfo tools result in text format)
- Code:
Complete name : F:\Dowloaded\Taghlid Seda.3gp
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 9.64 MiB
Duration : 5mn 28s
Overall bit rate : 246 Kbps
Movie name : New - Saman Gooran - Taghlide Sedaye [Ebi_ Adel Ferdosipour_ Mehran Modiri_ Shahram Homayoun_ K _ H_
Writing application : Lavf51.6.0
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : 20
Duration : 5mn 28s
Bit rate : 196 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 15.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.170
Stream size : 7.68 MiB (80%)
Writing library : Lavc51.25.0
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 5mn 28s
Bit rate mode : Variable
Bit rate : 48.0 Kbps
Channel(s) : 2 channels
Sampling rate : 16.0 KHz
Stream size : 1.88 MiB (19%)
Is this what you needed?
I've updated the profiles for 1.0, you'll be able to play 3gp then.
Petr
Help translate Serviio
what are .dat files? are they files from VCD?
Where can I find the updated profile for Sony in order to play .3gp?
Yes, by .dat I mean the VCD files.
they are currently being beta tested.
Petr
May I have the beta profiles?
they will only work with the beta version.
Petr
how can we get the beta version to stream .dat files. I have a lot files in .dat format, but unable to stream them. Need this file format support to play them. It is not possible to convert them all, please help.
abmsharif wrote:how can we get the beta version to stream .dat files. I have a lot files in .dat format, but unable to stream them. Need this file format support to play them. It is not possible to convert them all, please help.
Have you tried renaming .dat to .mpeg
Is 3gp working for Sony SMP N100? Do I need to edit the profile? I have updated to Version 1.01 and hoped it was working, but not.
This would be a really nice feature as I would be able to play recorded video from my phone easily. Great for home movies.
3gp should work, can you post ffmpeg -i of the file?
Petr
Thank you Zip for the quick reply...I am out of town until the 19th and I will post the results then. The symptom is when I navigate the SMP N100 to my phone directory for video, I get the message "there is no playable file". On my android phone I am using an app called pixel-dms to serve files to my SMP. Could that be where the problem lies? Is there a serviio app for android that will be a better choice? Thanks.
timnop wrote:Thank you Zip for the quick reply...I am out of town until the 19th and I will post the results then. The symptom is when I navigate the SMP N100 to my phone directory for video, I get the message "there is no playable file". On my android phone I am using an app called pixel-dms to serve files to my SMP. Could that be where the problem lies? Is there a serviio app for android that will be a better choice? Thanks.
Make sure you assign the IP of the android phone the Sony BDP profile.
Petr
• Page 1 of 1
