Can't play .3gp and .dat files on my Sony TV
remi1985
Post Fri May 25, 2012 4:07 pm
Thanks to Serviio, my Sony TV (40CX520) shows .mkv, .flv and etc, but it does not show .3gp and .dat files. Any idea?!
Post Fri May 25, 2012 7:09 pm
Re: Can't play .3gp and .dat files on my Sony TV
Could you provide information about .3gp and .dat file ? (see signature links) (ffmpeg -i <file> an MediaInfo tools result in text format)
remi1985
Post Wed May 30, 2012 9:42 pm
Complete name                            : F:\Dowloaded\Taghlid Seda.3gp
Format profile                           : 3GPP Media Release 4
Codec ID                                 : 3gp4
File size                                : 9.64 MiB
Duration                                 : 5mn 28s
Overall bit rate                         : 246 Kbps
Movie name                               : New - Saman Gooran - Taghlide Sedaye [Ebi_ Adel Ferdosipour_ Mehran Modiri_ Shahram Homayoun_ K _ H_
Writing application                      : Lavf51.6.0
Format                                   : MPEG-4 Visual
Format profile                           : Simple@L1
Format settings, BVOP                    : No
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : 20
Duration                                 : 5mn 28s
Bit rate                                 : 196 Kbps
Width                                    : 320 pixels
Height                                   : 240 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 15.000 fps
Bits/(Pixel*Frame)                       : 0.170
Stream size                              : 7.68 MiB (80%)
Writing library                          : Lavc51.25.0
Codec ID                                 : 40
Duration                                 : 5mn 28s
Bit rate                                 : 48.0 Kbps
Sampling rate                            : 16.0 KHz
Stream size                              : 1.88 MiB (19%)
Is this what you needed?
Post Wed May 30, 2012 9:52 pm
I've updated the profiles for 1.0, you'll be able to play 3gp then.
Xmantium
Post Thu May 31, 2012 11:44 am
what are .dat files? are they files from VCD?
remi1985
Post Thu May 31, 2012 5:42 pm
Where can I find the updated profile for Sony in order to play .3gp?
Yes, by .dat I mean the VCD files.
Post Thu May 31, 2012 9:40 pm
they are currently being beta tested.
remi1985
Post Sun Jun 03, 2012 5:32 am
May I have the beta profiles?
Post Sun Jun 03, 2012 11:12 am
they will only work with the beta version.
abmsharif
Post Fri Aug 03, 2012 6:46 am
how can we get the beta version to stream .dat files. I have a lot files in .dat format, but unable to stream them. Need this file format support to play them. It is not possible to convert them all, please help.
Xmantium
Post Mon Aug 13, 2012 12:07 am
abmsharif wrote:how can we get the beta version to stream .dat files. I have a lot files in .dat format, but unable to stream them. Need this file format support to play them. It is not possible to convert them all, please help.
Have you tried renaming .dat to .mpeg
timnop
Post Mon Aug 13, 2012 3:59 am
Is 3gp working for Sony SMP N100? Do I need to edit the profile? I have updated to Version 1.01 and hoped it was working, but not.
This would be a really nice feature as I would be able to play recorded video from my phone easily. Great for home movies.
Post Mon Aug 13, 2012 4:23 pm
3gp should work, can you post ffmpeg -i of the file?
timnop
Post Thu Aug 16, 2012 1:30 am
Thank you Zip for the quick reply...I am out of town until the 19th and I will post the results then. The symptom is when I navigate the SMP N100 to my phone directory for video, I get the message "there is no playable file". On my android phone I am using an app called pixel-dms to serve files to my SMP. Could that be where the problem lies? Is there a serviio app for android that will be a better choice? Thanks.
Post Thu Aug 16, 2012 11:04 am
timnop wrote:Thank you Zip for the quick reply...I am out of town until the 19th and I will post the results then. The symptom is when I navigate the SMP N100 to my phone directory for video, I get the message "there is no playable file". On my android phone I am using an app called pixel-dms to serve files to my SMP. Could that be where the problem lies? Is there a serviio app for android that will be a better choice? Thanks.
Make sure you assign the IP of the android phone the Sony BDP profile.
