Torrrent Stream Video Web Resource
Yorick
Post Mon Oct 01, 2012 4:26 pm
Hi eberybody!!
Torrent Stream is a Russian application which is starting to offer high quality online streams, typically sports events like football matches.
This is the webpage http://torrentstream.org/
Livefootball.ws and wiziwig.tv are starting to list live Torrrent Stream events and especially in HD quality.
Is it possible to develop a plugin to use Torrent Stream in Serviio?.
It would be great to enjoy HD sport events or movies on our TVs.
Thanks in advance!!
Vintila
Post Tue Oct 23, 2012 9:05 pm
Re: Torrrent Stream Video Web Resource
I second this plugin request!
devil2
Post Tue Oct 23, 2012 9:57 pm
me to ;)
Vintila
Post Wed Oct 24, 2012 8:18 am
I have read in this forum that which can be played in VLC can be played in Serviio. Well, these streams use VLC as player.
silvadalula
Post Sat Oct 27, 2012 3:00 pm
Vintila wrote:I have read in this forum that which can be played in VLC can be played in Serviio. Well, these streams use VLC as player.
TorrentStream will replace sopcast in soccer streaming. It is necesary develop a serviio pluging. I hope.
yugalex
Post Sun Oct 28, 2012 2:32 pm
I also subscribe! Torrent stream rulezzz! ;)
rsheller
Post Thu Nov 15, 2012 7:45 pm
I would also add my vote for a plugin using Torrrent Stream Video as a Web Resource.
Wingsgb
Post Sun Jan 20, 2013 2:52 am
Any thoughts on this? I am also very interested as sopcast has come to an end.
Reading on the acestream forums there API is open. There is a plugin for xbmc like everything else
someone4k
Post Mon Feb 18, 2013 11:11 pm
Hello guys. You can easily get this done by using VLC to output the stream on sopcast port/url so you dont need to change anything :)
Follow this easy guide http://forum.wiziwig.eu/threads/81442-T ... 5db1e94f21
Not CPU demanding, and you can turn off VLC local playback (display while streaming) by writing this instead:
#duplicate{dst="http{mux=ts,dst=:8902/tv.asf}"}
Torrentstream / Acestream
joostnl
Post Sat Feb 23, 2013 8:14 pm
Nice! But i can't get it to work... When I at a live stream to 'online sources' and even after a refresh the online folder is empty when browsing with my tv.
Yorick
Post Mon Feb 25, 2013 11:02 am
someone4k wrote:Hello guys. You can easily get this done by using VLC to output the stream on sopcast port/url so you dont need to change anything :)
I've tried that and it doesn´t work. Now the program isn´t TorrentStream, now it´s ACE Stream and everyday it´s more popular. So I keep the faith that someone developes the plugin.
someone4k
Post Mon Feb 25, 2013 3:00 pm
It does work if you do it correctly. You can verify it by "open network URL" in VLC: http://localhost:8902/tv.asf
Once verified: In Serviio you shouldnt open the Sopcast plugin, just a link to your local computer:8902/tv.asf (Restart serviio service and give it a few mins)
Yorick
Post Mon Feb 25, 2013 3:36 pm
someone4k wrote:It does work if you do it correctly. You can verify it by "open network URL" in VLC: http://localhost:8902/tv.asf
Would you mind to make a tutorial how to do it?. With step by step, screen captures and an example to can see it better. It would be helpful for many people.
Thanks in advance ;)
someone4k
Post Mon Feb 25, 2013 4:48 pm
Lol am I your servant or something? What is it you dont understand? I gave a link to a straight forward step by step tutorial on wiziwig. Did you get it to run in VLC?
rsheller
Post Wed Feb 27, 2013 8:33 pm
I will lower my self to saying, no, I cannot get it to run, but in my defence I do use the "Dummies" guides & admit I occasionally have to be spoon fed info slowly & bit by bit.
I am a learner albeit a slow one! :D
Yorick
Post Thu Feb 28, 2013 4:01 pm
someone4k wrote:Lol am I your servant or something? What is it you dont understand? I gave a link to a straight forward step by step tutorial on wiziwig. Did you get it to run in VLC?
Yeahhh you are my servant. Just kidding :lol: :lol:
First, I put the code #duplicate{dst="http{mux=ts,dst=:8902/tv.asf}",dst=display} in the Default Stream Output Chain field of TorrentStream Player and after I put http://localhost:8902/tv.asf in the Source URL of Serviio console like here:
The problem is that when I push the "Check stream URL button sometimes it works and sometimes not, how you can see in the image. And I don´t understand why :?
someone4k
Post Thu Feb 28, 2013 5:50 pm
With your settings you will also view the stream on your computer. Does it say prebuffering and then the video shows? It will only turn green in Serviio if there's actually something to stream. Also, while localhost works on your computer, you need to change it to your local ip for your TV to understand it. "localhost" was just for testing the output in another VLC window.
Since it sometimes turns green and sometimes not, the stream of your choice probably isnt good enough or your ISP is throttling torrent traffic.. = a lot of buffering
Yorick
Post Thu Feb 28, 2013 8:01 pm
I can to see perfectly the streams with the TorrentStream player with out buffering. So if I understand you, in Serviio console I have to put my PC local IP (192.168.1.30), for example http://192.168.1.30:8902/tv.asf, is this correct?.
With the Sopcast I have http://127.0.0.1:8902/ and it works perfectly in my TV. And 127.0.0.1 is the same that localhost http://en.wikipedia.org/wiki/Localhost
someone4k
Post Thu Feb 28, 2013 9:16 pm
Ok, if it works with Sopcast then localhost is valid for this workaround as well.
Exit Ace player and open it again and make sure Enable audio/video/SPU is checked and the "default output output chain" is there (as on screenshot from wiziwig). If it is everything is as it should be and I dont know what else to try. It does work on the 2 computers I've tried it on. The fact that "Check stream URL" is green sometimes shows that it works, but it should be green at all times as long as there is no buffering in Ace Player.
Yorick
Post Mon Mar 04, 2013 10:05 am
Thank you very much someone4k for your help. After to update the last version of Serviio, finally it works and now I can see HD Football in my Smart TV :)
Return to Plugin requests
Users browsing this forum: Baidu [Spider] and 2 guests
