Re: Unsupported File Format
zip wrote:did you try it in MediaBrowser?
I did not before.
It works on MediaBrowser! So do the other 4 files that were experiencing the same problem.
zip wrote:There should be at least 2 (thumbnail and the video).
zip wrote:It this supposed to be a folder of the file? The tool can sometimes load the contents slowly....
2012-10-27 08:26:26,104 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Beetlejuice (1988)
2012-10-27 08:26:26,104 DEBUG [LibraryAdditionsCheckerThread] Found file 'Renamed.m4v', checking if it's already in the Library
2012-10-27 08:26:26,104 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Renamed.m4v
2012-10-27 08:26:26,104 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Beetlejuice (1988)\Renamed.m4v, ignore case: true
2012-10-27 08:26:26,104 DEBUG [MediaItemDAOImpl] Media item Renamed.m4v doesn't exist in DB yet
2012-10-27 08:26:26,104 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-10-27 08:26:26,104 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\Beetlejuice (1988)\Renamed.m4v
2012-10-27 08:26:26,104 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\Beetlejuice (1988)\Renamed.m4v
2012-10-27 08:26:26,114 DEBUG [MediaItemDAOImpl] Getting file of media item 218
2012-10-27 08:26:26,114 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 218) and extractor EMBEDDED
2012-10-27 08:26:26,117 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 218) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,117 DEBUG [MediaItemDAOImpl] Getting file of media item 219
2012-10-27 08:26:26,118 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 219) and extractor EMBEDDED
2012-10-27 08:26:26,118 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 219) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,118 DEBUG [MediaItemDAOImpl] Getting file of media item 220
2012-10-27 08:26:26,118 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 220) and extractor EMBEDDED
2012-10-27 08:26:26,118 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 220) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,119 DEBUG [MediaItemDAOImpl] Getting file of media item 221
2012-10-27 08:26:26,119 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 221) and extractor EMBEDDED
2012-10-27 08:26:26,119 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 221) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,119 DEBUG [MediaItemDAOImpl] Getting file of media item 222
2012-10-27 08:26:26,119 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 222) and extractor EMBEDDED
2012-10-27 08:26:26,120 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 222) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,120 DEBUG [MediaItemDAOImpl] Getting file of media item 223
2012-10-27 08:26:26,120 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 223) and extractor EMBEDDED
2012-10-27 08:26:26,120 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 223) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,121 DEBUG [MediaItemDAOImpl] Getting file of media item 224
2012-10-27 08:26:26,121 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 224) and extractor EMBEDDED
2012-10-27 08:26:26,121 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 224) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,121 DEBUG [MediaItemDAOImpl] Getting file of media item 225
2012-10-27 08:26:26,121 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 225) and extractor EMBEDDED
2012-10-27 08:26:26,121 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 225) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,122 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\Beetlejuice (1988)\Renamed.m4v
2012-10-27 08:26:26,122 DEBUG [MediaItemDAOImpl] Getting file of media item 226
2012-10-27 08:26:26,122 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 226) and extractor EMBEDDED
2012-10-27 08:26:26,122 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 226) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,123 DEBUG [MediaItemDAOImpl] Getting file of media item 227
2012-10-27 08:26:26,123 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 227) and extractor EMBEDDED
2012-10-27 08:26:26,123 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 227) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,123 DEBUG [MediaItemDAOImpl] Getting file of media item 228
2012-10-27 08:26:26,123 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 228) and extractor EMBEDDED
2012-10-27 08:26:26,124 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 228) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,124 DEBUG [MediaItemDAOImpl] Getting file of media item 229
2012-10-27 08:26:26,124 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 229) and extractor EMBEDDED
2012-10-27 08:26:26,124 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 229) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,125 DEBUG [MediaItemDAOImpl] Getting file of media item 230
2012-10-27 08:26:26,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 230) and extractor EMBEDDED
2012-10-27 08:26:26,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 230) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,125 DEBUG [MediaItemDAOImpl] Getting file of media item 231
2012-10-27 08:26:26,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 231) and extractor EMBEDDED
2012-10-27 08:26:26,126 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 231) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,126 DEBUG [MediaItemDAOImpl] Getting file of media item 232
2012-10-27 08:26:26,126 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 232) and extractor EMBEDDED
2012-10-27 08:26:26,126 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 232) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,126 DEBUG [MediaItemDAOImpl] Getting file of media item 233
2012-10-27 08:26:26,126 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 233) and extractor EMBEDDED
2012-10-27 08:26:26,127 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 233) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,127 DEBUG [MediaItemDAOImpl] Getting file of media item 234
2012-10-27 08:26:26,127 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 234) and extractor EMBEDDED
2012-10-27 08:26:26,127 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 234) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,127 DEBUG [MediaItemDAOImpl] Getting file of media item 235
2012-10-27 08:26:26,128 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 235) and extractor EMBEDDED
2012-10-27 08:26:26,128 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 235) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,131 DEBUG [MediaItemDAOImpl] Getting file of media item 236
2012-10-27 08:26:26,131 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 236) and extractor EMBEDDED
2012-10-27 08:26:26,131 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 236) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,131 DEBUG [MediaItemDAOImpl] Getting file of media item 237
2012-10-27 08:26:26,131 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 237) and extractor EMBEDDED
2012-10-27 08:26:26,132 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 237) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,132 DEBUG [MediaItemDAOImpl] Getting file of media item 238
2012-10-27 08:26:26,132 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 238) and extractor EMBEDDED
2012-10-27 08:26:26,132 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 238) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,132 DEBUG [MediaItemDAOImpl] Getting file of media item 239
2012-10-27 08:26:26,132 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 239) and extractor EMBEDDED
2012-10-27 08:26:26,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 239) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,133 DEBUG [MediaItemDAOImpl] Getting file of media item 240
2012-10-27 08:26:26,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 240) and extractor EMBEDDED
2012-10-27 08:26:26,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 240) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,134 DEBUG [MediaItemDAOImpl] Getting file of media item 241
2012-10-27 08:26:26,134 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 241) and extractor EMBEDDED
2012-10-27 08:26:26,134 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 241) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,134 DEBUG [MediaItemDAOImpl] Getting file of media item 242
2012-10-27 08:26:26,134 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 242) and extractor EMBEDDED
2012-10-27 08:26:26,135 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 242) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,135 DEBUG [MediaItemDAOImpl] Getting file of media item 243
2012-10-27 08:26:26,135 INFO [LibraryUpdatesCheckerThread] Removing 'Beetlejuice' (D:\Beetlejuice (1988)\Beetlejuice (1988).m4v) from Library
2012-10-27 08:26:26,135 DEBUG [VideoDAOImpl] Reading a Video (id = 243)
2012-10-27 08:26:26,135 DEBUG [VideoService] Removing video from database: Beetlejuice
2012-10-27 08:26:26,135 DEBUG [PersonDAOImpl] Removing all Persons from media item 243
2012-10-27 08:26:26,135 DEBUG [PersonDAOImpl] Retrieving list of persons for MediaItem 243
2012-10-27 08:26:26,141 DEBUG [PersonDAOImpl] Found all Persons (19) for media item 243
2012-10-27 08:26:26,160 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2951
2012-10-27 08:26:26,162 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2952
2012-10-27 08:26:26,162 DEBUG [PersonDAOImpl] Deleting a Person (id = 2952)
2012-10-27 08:26:26,169 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2953
2012-10-27 08:26:26,170 DEBUG [PersonDAOImpl] Deleting a Person (id = 2953)
2012-10-27 08:26:26,170 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2954
2012-10-27 08:26:26,170 DEBUG [PersonDAOImpl] Deleting a Person (id = 2954)
2012-10-27 08:26:26,171 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2955
2012-10-27 08:26:26,171 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2956
2012-10-27 08:26:26,171 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2957
2012-10-27 08:26:26,171 DEBUG [PersonDAOImpl] Deleting a Person (id = 2957)
2012-10-27 08:26:26,172 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2958
2012-10-27 08:26:26,172 DEBUG [PersonDAOImpl] Deleting a Person (id = 2958)
2012-10-27 08:26:26,173 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2959
2012-10-27 08:26:26,173 DEBUG [PersonDAOImpl] Deleting a Person (id = 2959)
2012-10-27 08:26:26,174 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2960
2012-10-27 08:26:26,174 DEBUG [PersonDAOImpl] Deleting a Person (id = 2960)
2012-10-27 08:26:26,174 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2961
2012-10-27 08:26:26,175 DEBUG [PersonDAOImpl] Deleting a Person (id = 2961)
2012-10-27 08:26:26,175 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2962
2012-10-27 08:26:26,175 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2963
2012-10-27 08:26:26,175 DEBUG [PersonDAOImpl] Deleting a Person (id = 2963)
2012-10-27 08:26:26,176 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2964
2012-10-27 08:26:26,176 DEBUG [PersonDAOImpl] Deleting a Person (id = 2964)
2012-10-27 08:26:26,177 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2965
2012-10-27 08:26:26,177 DEBUG [PersonDAOImpl] Deleting a Person (id = 2965)
2012-10-27 08:26:26,177 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2966
2012-10-27 08:26:26,178 DEBUG [PersonDAOImpl] Deleting a Person (id = 2966)
2012-10-27 08:26:26,178 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2967
2012-10-27 08:26:26,178 DEBUG [PersonDAOImpl] Deleting a Person (id = 2967)
2012-10-27 08:26:26,179 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2968
2012-10-27 08:26:26,179 DEBUG [PersonDAOImpl] Deleting a Person (id = 2968)
2012-10-27 08:26:26,180 DEBUG [PersonDAOImpl] Retrieving number of roles for person 2969
2012-10-27 08:26:26,180 DEBUG [PersonDAOImpl] Deleting a Person (id = 2969)
2012-10-27 08:26:26,191 DEBUG [MetadataDescriptorDAOImpl] Deleting all MetadataDescriptors for MediaItem (id = 243)
2012-10-27 08:26:26,194 DEBUG [VideoDAOImpl] Deleting a Video (id = 243)
2012-10-27 08:26:26,200 DEBUG [CoverImageDAOImpl] Deleting a CoverImage (id = 243)
2012-10-27 08:26:26,206 DEBUG [FolderDAOImpl] Reading a Folder (id = 243)
2012-10-27 08:26:26,206 DEBUG [FolderDAOImpl] Getting number of media items in folder 243
2012-10-27 08:26:26,210 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 243 [Any]
2012-10-27 08:26:26,212 DEBUG [FolderDAOImpl] Deleting a Folder (id = 243)
2012-10-27 08:26:26,219 DEBUG [FolderDAOImpl] Reading a Folder (id = 217)
2012-10-27 08:26:26,220 DEBUG [FolderDAOImpl] Getting number of media items in folder 217
2012-10-27 08:26:26,220 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 217 [Any]
2012-10-27 08:26:26,223 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'D:\Beetlejuice (1988)\Renamed.m4v'
2012-10-27 08:26:26,223 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: D:\Beetlejuice (1988)\Renamed.m4v
2012-10-27 08:26:26,223 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\Beetlejuice (1988)\Renamed.m4v -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-10-27 08:26:26,223 DEBUG [GenreDAOImpl] Getting number of media items for genre 24
2012-10-27 08:26:26,336 DEBUG [MediaItemDAOImpl] Getting file of media item 438
2012-10-27 08:26:26,336 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 438) and extractor EMBEDDED
2012-10-27 08:26:26,336 DEBUG [FFmpegMetadataRetriever] File 'D:\Beetlejuice (1988)\Renamed.m4v' has H264 profile HIGH, level 4 and 4 ref frames
2012-10-27 08:26:26,336 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: D:\Beetlejuice (1988)\Renamed.m4v
2012-10-27 08:26:26,336 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 438) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 08:26:26,336 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i D:\Beetlejuice (1988)\Renamed.m4v -an -frames:v 1 -f image2 pipe:
2012-10-27 08:26:26,366 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2012-10-27 08:26:27,604 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=Renamed, filePath=D:\Beetlejuice (1988)\Renamed.m4v, fileSize=5751845517, audioBitrate=159, audioCodec=AAC, audioStreamIndex=1, bitrate=8326, channels=2, container=MP4, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@16d22a96, duration=5526, episodeNumber=null, fps=23.976, frequency=48000, h264Level=4, h264Profile=HIGH, mkvHeaderCompression=null, ftyp=mp42, height=1088, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=7520, videoCodec=H264, videoStreamIndex=0, width=1920]
2012-10-27 08:26:27,609 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'renamed' 1988 (language: en)
2012-10-27 08:26:27,739 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2012-10-27 08:26:27,739 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'beetlejuice' 1988 (language: en)
2012-10-27 08:26:27,967 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2012-10-27 08:26:27,978 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 4011
2012-10-27 08:26:27,978 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 4011, language = en)
2012-10-27 08:26:28,577 DEBUG [TheMovieDBSourceAdaptor] Retrieved poster: http://cf2.imgobject.com/t/p/w185/gWnW7vxm8yr01TVLQhL4aI02orp.jpg
2012-10-27 08:26:28,577 DEBUG [LibraryManager] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=Beetlejuice, filePath=null, fileSize=0, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=null, channels=null, container=null, contentType=MOVIE, coverImage=org.serviio.library.local.metadata.ImageDescriptor@57c5e777, duration=null, episodeNumber=null, fps=null, frequency=null, h264Level=null, h264Profile=null, mkvHeaderCompression=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoStreamIndex=null, width=null]
2012-10-27 08:26:28,577 DEBUG [VideoService] Adding video into database: Beetlejuice
2012-10-27 08:26:28,578 DEBUG [FolderDAOImpl] Looking for folder hierarchy BDRip Handbrake\Beetlejuice (1988)
2012-10-27 08:26:28,603 DEBUG [GenreDAOImpl] Reading a Genre (name = Fantasy)
2012-10-27 08:26:28,605 DEBUG [GenreService] Genre Fantasy found
2012-10-27 08:26:28,605 DEBUG [CoverImageService] Resizing and storing cover art image
2012-10-27 08:26:28,606 DEBUG [ImageUtils] Starting image resize, size = 15093 bytes
2012-10-27 08:26:28,687 DEBUG [ImageUtils] Returning resized image, size = 6206 bytes
2012-10-27 08:26:28,687 DEBUG [CoverImageService] Image successfully resized
2012-10-27 08:26:28,687 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 6206)
2012-10-27 08:26:28,691 DEBUG [VideoDAOImpl] Creating a new Video (title = Beetlejuice)
2012-10-27 08:26:28,711 DEBUG [PersonDAOImpl] Adding a Person Tim Burton to media item 482 as DIRECTOR
2012-10-27 08:26:28,711 DEBUG [PersonDAOImpl] Reading a Person (name = Tim Burton)
2012-10-27 08:26:28,713 DEBUG [PersonDAOImpl] Checking if person 2951 has a role DIRECTOR for media item 482
2012-10-27 08:26:28,724 DEBUG [PersonDAOImpl] Adding a Person Michael Bender to media item 482 as PRODUCER
2012-10-27 08:26:28,724 DEBUG [PersonDAOImpl] Reading a Person (name = Michael Bender)
2012-10-27 08:26:28,724 DEBUG [PersonDAOImpl] Creating a new Person (name = Michael Bender)
2012-10-27 08:26:28,727 DEBUG [PersonDAOImpl] Checking if person 5447 has a role PRODUCER for media item 482
2012-10-27 08:26:28,734 DEBUG [PersonDAOImpl] Adding a Person Richard Hashimoto to media item 482 as PRODUCER
2012-10-27 08:26:28,734 DEBUG [PersonDAOImpl] Reading a Person (name = Richard Hashimoto)
2012-10-27 08:26:28,735 DEBUG [PersonDAOImpl] Creating a new Person (name = Richard Hashimoto)
2012-10-27 08:26:28,736 DEBUG [PersonDAOImpl] Checking if person 5448 has a role PRODUCER for media item 482
2012-10-27 08:26:28,737 DEBUG [PersonDAOImpl] Adding a Person Larry Wilson to media item 482 as PRODUCER
2012-10-27 08:26:28,737 DEBUG [PersonDAOImpl] Reading a Person (name = Larry Wilson)
2012-10-27 08:26:28,737 DEBUG [PersonDAOImpl] Creating a new Person (name = Larry Wilson)
2012-10-27 08:26:28,738 DEBUG [PersonDAOImpl] Checking if person 5449 has a role PRODUCER for media item 482
2012-10-27 08:26:28,739 DEBUG [PersonDAOImpl] Adding a Person Michael Keaton to media item 482 as ACTOR
2012-10-27 08:26:28,739 DEBUG [PersonDAOImpl] Reading a Person (name = Michael Keaton)
2012-10-27 08:26:28,739 DEBUG [PersonDAOImpl] Checking if person 2955 has a role ACTOR for media item 482
2012-10-27 08:26:28,741 DEBUG [PersonDAOImpl] Adding a Person Alec Baldwin to media item 482 as ACTOR
2012-10-27 08:26:28,741 DEBUG [PersonDAOImpl] Reading a Person (name = Alec Baldwin)
2012-10-27 08:26:28,741 DEBUG [PersonDAOImpl] Checking if person 2956 has a role ACTOR for media item 482
2012-10-27 08:26:28,743 DEBUG [PersonDAOImpl] Adding a Person Geena Davis to media item 482 as ACTOR
2012-10-27 08:26:28,743 DEBUG [PersonDAOImpl] Reading a Person (name = Geena Davis)
2012-10-27 08:26:28,743 DEBUG [PersonDAOImpl] Creating a new Person (name = Geena Davis)
2012-10-27 08:26:28,744 DEBUG [PersonDAOImpl] Checking if person 5450 has a role ACTOR for media item 482
2012-10-27 08:26:28,745 DEBUG [PersonDAOImpl] Adding a Person Annie McEnroe to media item 482 as ACTOR
2012-10-27 08:26:28,745 DEBUG [PersonDAOImpl] Reading a Person (name = Annie McEnroe)
2012-10-27 08:26:28,745 DEBUG [PersonDAOImpl] Creating a new Person (name = Annie McEnroe)
2012-10-27 08:26:28,746 DEBUG [PersonDAOImpl] Checking if person 5451 has a role ACTOR for media item 482
2012-10-27 08:26:28,748 DEBUG [PersonDAOImpl] Adding a Person Maurice Page to media item 482 as ACTOR
2012-10-27 08:26:28,748 DEBUG [PersonDAOImpl] Reading a Person (name = Maurice Page)
2012-10-27 08:26:28,748 DEBUG [PersonDAOImpl] Creating a new Person (name = Maurice Page)
2012-10-27 08:26:28,749 DEBUG [PersonDAOImpl] Checking if person 5452 has a role ACTOR for media item 482
2012-10-27 08:26:28,750 DEBUG [PersonDAOImpl] Adding a Person Hugo Stanger to media item 482 as ACTOR
2012-10-27 08:26:28,750 DEBUG [PersonDAOImpl] Reading a Person (name = Hugo Stanger)
2012-10-27 08:26:28,750 DEBUG [PersonDAOImpl] Creating a new Person (name = Hugo Stanger)
2012-10-27 08:26:28,751 DEBUG [PersonDAOImpl] Checking if person 5453 has a role ACTOR for media item 482
2012-10-27 08:26:28,752 DEBUG [PersonDAOImpl] Adding a Person Rachel Mittelman to media item 482 as ACTOR
2012-10-27 08:26:28,752 DEBUG [PersonDAOImpl] Reading a Person (name = Rachel Mittelman)
2012-10-27 08:26:28,752 DEBUG [PersonDAOImpl] Creating a new Person (name = Rachel Mittelman)
2012-10-27 08:26:28,753 DEBUG [PersonDAOImpl] Checking if person 5454 has a role ACTOR for media item 482
2012-10-27 08:26:28,754 DEBUG [PersonDAOImpl] Adding a Person Winona Ryder to media item 482 as ACTOR
2012-10-27 08:26:28,754 DEBUG [PersonDAOImpl] Reading a Person (name = Winona Ryder)
2012-10-27 08:26:28,754 DEBUG [PersonDAOImpl] Checking if person 2962 has a role ACTOR for media item 482
2012-10-27 08:26:28,756 DEBUG [PersonDAOImpl] Adding a Person Catherine O'Hara to media item 482 as ACTOR
2012-10-27 08:26:28,756 DEBUG [PersonDAOImpl] Reading a Person (name = Catherine O'Hara)
2012-10-27 08:26:28,756 DEBUG [PersonDAOImpl] Creating a new Person (name = Catherine O'Hara)
2012-10-27 08:26:28,756 DEBUG [PersonDAOImpl] Checking if person 5455 has a role ACTOR for media item 482
2012-10-27 08:26:28,758 DEBUG [PersonDAOImpl] Adding a Person J. Jay Saunders to media item 482 as ACTOR
2012-10-27 08:26:28,758 DEBUG [PersonDAOImpl] Reading a Person (name = J. Jay Saunders)
2012-10-27 08:26:28,758 DEBUG [PersonDAOImpl] Creating a new Person (name = J. Jay Saunders)
2012-10-27 08:26:28,759 DEBUG [PersonDAOImpl] Checking if person 5456 has a role ACTOR for media item 482
2012-10-27 08:26:28,760 DEBUG [PersonDAOImpl] Adding a Person Mark Ettlinger to media item 482 as ACTOR
2012-10-27 08:26:28,760 DEBUG [PersonDAOImpl] Reading a Person (name = Mark Ettlinger)
2012-10-27 08:26:28,760 DEBUG [PersonDAOImpl] Creating a new Person (name = Mark Ettlinger)
2012-10-27 08:26:28,761 DEBUG [PersonDAOImpl] Checking if person 5457 has a role ACTOR for media item 482
2012-10-27 08:26:28,762 DEBUG [PersonDAOImpl] Adding a Person Jeffrey Jones to media item 482 as ACTOR
2012-10-27 08:26:28,762 DEBUG [PersonDAOImpl] Reading a Person (name = Jeffrey Jones)
2012-10-27 08:26:28,763 DEBUG [PersonDAOImpl] Creating a new Person (name = Jeffrey Jones)
2012-10-27 08:26:28,763 DEBUG [PersonDAOImpl] Checking if person 5458 has a role ACTOR for media item 482
2012-10-27 08:26:28,765 DEBUG [PersonDAOImpl] Adding a Person Glenn Shadix to media item 482 as ACTOR
2012-10-27 08:26:28,765 DEBUG [PersonDAOImpl] Reading a Person (name = Glenn Shadix)
2012-10-27 08:26:28,765 DEBUG [PersonDAOImpl] Creating a new Person (name = Glenn Shadix)
2012-10-27 08:26:28,766 DEBUG [PersonDAOImpl] Checking if person 5459 has a role ACTOR for media item 482
2012-10-27 08:26:28,767 DEBUG [PersonDAOImpl] Adding a Person Patrice Martinez to media item 482 as ACTOR
2012-10-27 08:26:28,767 DEBUG [PersonDAOImpl] Reading a Person (name = Patrice Martinez)
2012-10-27 08:26:28,767 DEBUG [PersonDAOImpl] Creating a new Person (name = Patrice Martinez)
2012-10-27 08:26:28,769 DEBUG [PersonDAOImpl] Checking if person 5460 has a role ACTOR for media item 482
2012-10-27 08:26:28,770 DEBUG [PersonDAOImpl] Adding a Person Cindy Daly to media item 482 as ACTOR
2012-10-27 08:26:28,770 DEBUG [PersonDAOImpl] Reading a Person (name = Cindy Daly)
2012-10-27 08:26:28,770 DEBUG [PersonDAOImpl] Creating a new Person (name = Cindy Daly)
2012-10-27 08:26:28,771 DEBUG [PersonDAOImpl] Checking if person 5461 has a role ACTOR for media item 482
2012-10-27 08:26:28,772 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 482)
2012-10-27 08:26:28,775 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 482)
2012-10-27 08:26:28,776 INFO [LibraryAdditionsCheckerThread] Added file 'Renamed.m4v' (title: Beetlejuice) to Library
2012-10-27 08:27:42,876 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Beetlejuice (1988)
2012-10-27 08:27:42,876 DEBUG [LibraryAdditionsCheckerThread] Found file 'Renamed.m4v', checking if it's already in the Library
2012-10-27 08:27:42,876 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Renamed.m4v
2012-10-27 08:27:42,876 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Beetlejuice (1988)\Renamed.m4v, ignore case: true
2012-10-27 08:27:42,877 DEBUG [MediaItemDAOImpl] Media item Renamed.m4v already exists in DB
2012-10-27 08:27:43,060 DEBUG [MediaItemDAOImpl] Getting file of media item 482
2012-10-27 08:27:43,060 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 482) and extractor EMBEDDED
2012-10-27 08:27:43,060 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 482) and extractor COVER_IMAGE_IN_FOLDER
zip wrote:did you update your profiles.xml in any way?
zip wrote:Which profile are you using?
zip wrote:Ok, I think it's because the height of the video is 1088, which is more than the max. of 1080. You can see 2 qualities in ServiiGo/MediaBrowser because they transcode to lower resolution.
Users browsing this forum: No registered users and 55 guests
