LG 32LM340S and subfiles
Mister XY
Post Fri Mar 22, 2013 4:36 pm
Hello, is it possible to watch/transcode movies with .sub files
I have an LG TV and it's only support srt files. But the most subfiles are in the .sub .idx files format.
Post Sat Mar 23, 2013 1:48 am
Re: LG 32LM340S and subfiles
Serviio will find then and serve them as srt, so it should work, even without transcoding (the .sub that is)
Mister XY
Post Sat Mar 23, 2013 11:15 am
Really, i dint see that and when i show a movie with .sub files, i cant see subfiles. Which libarys must i compile for ffmpeg and what must be enableß
Post Sat Mar 23, 2013 1:42 pm
just select Enable subtitles in the console. It it still doesn't work, post detailed log of playing the file.
Mister XY
Post Sat Mar 23, 2013 7:08 pm
I use serviio 1.2 on the Zyxel NSA 325
Mister XY
Post Sat Mar 23, 2013 7:28 pm
Hello, here is the log.
(117.31 KiB) Downloaded 716 times
Post Sat Mar 23, 2013 9:11 pm
which file were you trying to play with the .sub file? What is the name of the file and the .sub file?
Mister XY
Post Sun Mar 24, 2013 5:28 am
The name of the file is Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.mkv the name of the sub file is Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.sub, Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.srt and Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.idx, if i rename Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.srt to Prometheus.Dunkle.Zeichen.2012.German.AC3.BDRip.x264-WodkaE.old , i did not see subtitle.
when i play the movie, the tmp directory is empty.
Must i need a ffmpeg-wrapper? And where get i ffmpeg-wrapper for my nsa 325?
Now, i have copy the directory with subtiles ans Movie to my windows 7 HDD and look if is work with the serviio 1.2 version for Windows and i dont see any subtitles. I only see srt subtitles. When i remove this subtitles, sub subtitles didn't shown.
Post Tue Mar 26, 2013 10:00 am
The file name is not present in the log, try to play it again and post the new log.
Mister XY
Post Wed Mar 27, 2013 9:11 am
Hello, i now i have change "feste Untertitel aktivieren" to "immer" and now, serviio wants to transcode.
in attachment, there is the log.
(159.84 KiB) Downloaded 693 times
Post Wed Mar 27, 2013 2:47 pm
First of all, let's try to solve this error: What is your FFmpeg version and is it built with support for libass?
Second, this should work without burning-in subs, disable that and post detailed log again.
