Is there any way to rename presentation items?
• Page 1 of 1
So my TV lists these items alphabetically, but I would like to have Folders-item before anything else (Actors, Directors...). If I could rename "Folders" to be in parenthesis like "(Folders)" it should work. Is there any way to do this by editing some text file or so?
Re: Is there any way to rename presentation items?
Very helpful of you, thanks.
these are spam. google for meaning if you don't know what it is.
You can't do that unless you're up to editing some files inside the jar files
Petr
Help translate Serviio
zip wrote:You can't do that unless you're up to editing some files inside the jar files
I'm up for it if it doesn't mean like editing 100 different files. What files should be edited?
Iveky wrote:these are spam. google for meaning if you don't know what it is.
Thanks a bunch!
Unzip Serviio.jar and edit file browse_categories.messages (for your preferred language). Then zip it back up into the jar file. Btw, the file name might not be exactly this, I don't have the code handy now.
Petr
zip wrote:Unzip Serviio.jar and edit file browse_categories.messages (for your preferred language). Then zip it back up into the jar file. Btw, the file name might not be exactly this, I don't have the code handy now.
Found them!
\org\serviio\upnp\service\contentdirectory\definition\i18n\browsingCategories_[??].properties, where [??] is the language suffix.
Works like a charm. Such a minor tweak but makes it much simpler experience to browse. Thanks!
• Page 1 of 1
Users browsing this forum: Baidu [Spider], Google [Bot] and 29 guests
