Is there any way to rename presentation items?
Manala
Post Tue Dec 31, 2013 11:38 pm
So my TV lists these items alphabetically, but I would like to have Folders-item before anything else (Actors, Directors...). If I could rename "Folders" to be in parenthesis like "(Folders)" it should work. Is there any way to do this by editing some text file or so?
Manala
Post Wed Jan 01, 2014 5:31 am
Re: Is there any way to rename presentation items?
Very helpful of you, thanks.
Iveky
Post Wed Jan 01, 2014 7:36 am
these are spam. google for meaning if you don't know what it is.
Post Fri Jan 03, 2014 11:22 am
You can't do that unless you're up to editing some files inside the jar files
Manala
Post Sun Jan 05, 2014 7:26 pm
zip wrote:You can't do that unless you're up to editing some files inside the jar files
I'm up for it if it doesn't mean like editing 100 different files. What files should be edited?
Iveky wrote:these are spam. google for meaning if you don't know what it is.
Thanks a bunch!
Post Mon Jan 06, 2014 8:15 am
Unzip Serviio.jar and edit file browse_categories.messages (for your preferred language). Then zip it back up into the jar file. Btw, the file name might not be exactly this, I don't have the code handy now.
Manala
Post Mon Jan 06, 2014 4:08 pm
zip wrote:Unzip Serviio.jar and edit file browse_categories.messages (for your preferred language). Then zip it back up into the jar file. Btw, the file name might not be exactly this, I don't have the code handy now.
Found them!
\org\serviio\upnp\service\contentdirectory\definition\i18n\browsingCategories_[??].properties, where [??] is the language suffix.
Works like a charm. Such a minor tweak but makes it much simpler experience to browse. Thanks!
