Can not connect to Serviio Server, it does not appear to be
Brutus814
Post Fri Feb 28, 2014 7:09 am
Hi, I recently had a memory stick in my computer go bad, so during the process of figuring out what was wrong, I had to system restore to a few weeks ago. When I got everything up and running again, it gave me the error "Can not connect to Serviio server, it does not appear to be online." I have confirmed that the service is indeed running. When I click on the Serviio Console, it waits for a while, then returns with the previous error. I uninstalled both Serviio and Java several times and used the old Java version uninstaller. I reinstalled both Serviio and Java and continue to get this error. I will attach a detailed log report of my most recent attempt. Thank you in advance for your help!
(205.99 KiB) Downloaded 457 times
Post Fri Feb 28, 2014 1:37 pm
Re: Can not connect to Serviio Server, it does not appear to
Log looks ok. Is the server on the same machine?
what if you try to open this in your browser?
http://192.168.0.108:23423/rest/application
Brutus814
Post Fri Feb 28, 2014 2:10 pm
Thank you for your quick response. When I open the requested line in my web browser I get:
-<application>
<version>1.4</version>
<edition>PRO</edition>
-<license>
<type>EVALUATION</type>
<expiresInMinutes>21076</expiresInMinutes>
</license>
<databaseUpdateId>ab575f9128004e6482b3e693f692227b</databaseUpdateId>
</application>
Thanks!
Brutus814
Post Fri Feb 28, 2014 2:25 pm
The server is on the same machine. The service is running and it can be accessed by different devices around the house but there is no media in the folders because I reinstalled it and have not been able to set up the folders in the console.
Thanks!
Brutus814
Post Fri Feb 28, 2014 3:08 pm
I have attached another log detailed log file after it ran overnight and I got the can not connect to server message a couple more times, just in case it showed something different.
Thanks!
(197.96 KiB) Downloaded 435 times
Brutus814
Post Sat Mar 01, 2014 1:28 am
Sorry for the repeated posts, but I checked the log again tonight and there are several entries for ServiioConsole, for example:
2014-02-28 17:43:20,263 INFO [ServiioConsole] Initializing Serviio Console
2014-02-28 17:43:20,283 INFO [ServiioConsole] Starting Serviio Console
2014-02-28 17:43:20,573 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-02-28 17:43:46,207 INFO [FeedUpdaterThread] Started looking for information about online resources
2014-02-28 17:43:46,211 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-28 17:43:46,218 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-28 17:43:46,218 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-02-28 17:45:30,731 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-02-28 17:47:40,759 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection timed out: connect
2014-02-28 17:47:40,766 INFO [Messages] Loaded console message bundle for locale: en
2014-02-28 19:22:30,219 INFO [ServiioConsole] Exitting Serviio Console
So, I have attached my latest serviio.log if this helps at all.
Thanks!
(79.13 KiB) Downloaded 417 times
Brutus814
Post Wed Mar 05, 2014 3:15 pm
Any other thoughts anyone? Your help is appreciated!
